Old 05-03-2021, 23:04   #1 (permalink)
Member: 1603212
Thanks Meter: 19
help redmi 9at
help friends after eng rom redmi 9at error emi already tested all levels of emi 01-99
sw unsuccessful always error emi
Operation : Identify [ v2.22 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM19)
MODE : BOOTROM
PORT : 19
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Cervino
TYPE : MODERN RAPHAEL
BROM : MEID : A948F7B1CE8D03CC057B467C6DE7E7EF
BROM : SecLevel : 0x000000E7
BROM : SecMode : SBC+SLA+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v2112 | Manual : Disabled
BROM : SOCID : AE8CBB871CDE154BB101911135C3C1F09E75B07352D294F1A6 9729DBEE710652
BROM : SLA : Local Auth
BROM : SLA : Auth Started!
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : PRELOADER_INFINITY_0
EMI : CNT : 0008
EMI : Init EMI from INTERNAL DB
DA : SETUP EMI PARAMS FAILED!
ERROR : ABORT
Error : Fail to init protocol!
>>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device!
Reconnect Power/Cable!
Old 05-04-2021, 04:02   #2 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 4,459
Select preloader from factory firmware
Old 05-04-2021, 04:17   #3 (permalink)
Member: 1603212
Thanks Meter: 19
yes friend try eng rom redmi 9a
Old 05-04-2021, 04:19   #4 (permalink)
Member: 1603212
Thanks Meter: 19
can someone help me eng rom redmi 9at
since my model does not run with try with several sw
no result eng rom redmi 9a does not work
Old 05-04-2021, 04:21   #5 (permalink)
Member: 1603212
Thanks Meter: 19
need this file someone who has it
Redmi 9AT ENG Firmware (Engineering Rom)
Old 05-05-2021, 04:12   #6 (permalink)
Member: 1603212
Thanks Meter: 19
Greetings friends, is there any special sw
Old 05-05-2021, 04:56   #7 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,124
try to reinstall 2.21 software version and try again, there is a bug in 2.22
The Following User Says Thank You to ribbentrop For This Useful Post:
Old 05-07-2021, 12:10   #8 (permalink)
Member: 148515
Thanks Meter: 17,782
It should be fixed with v2.23 https://forum.gsmhosting.com/vbb/f29...tures-2967422/
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.15449 seconds with 8 queries
