08-17-2015, 14:32 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | SC7715/SC7730/SC7731/SC8830 - SP locked? Looking for Beta testers. Looking for users with phones on hands to make some public solution. |
The Following 5 Users Say Thank You to JayDi For This Useful Post: |
08-19-2015, 04:43 | #8 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
There is clearly explained what I loking for. Nothing more. | |
08-19-2015, 14:35 | #9 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Plz added next update SC7715 NAND Q Mobile X6i 3G Code: Operation : Check/Read Info [ v1.03 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 70 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:11 Reconnect Power/Cable! Read PatternLock Code: Operation : Read PatternLock [ v1.03 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 70 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Unknown structure detected! Something went wrong :( If phone work normally - send report to support! Elapsed: 00:00:13 Reconnect Power/Cable! |
08-19-2015, 15:27 | #10 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | 1. This thread about samples for UNLOCK! Not adding some model! 2. http://forum.gsmhosting.com/vbb/f296...6i-3g-1980229/ Looks like it supported already. Charge battery and try again, please. |
08-19-2015, 15:53 | #12 (permalink) | |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Quote:
08-19-2015, 18:57 | #15 (permalink) | ||
http://forum.gsmhosting.com/vbb/f296...-lock-1981026/ Quote:
