Old 12-21-2008, 11:07   #1 (permalink)
3stanGsm's Avatar
Member: 331390
Thanks Meter: 434
C701x Auto-off done!
C701x Auto-off done with Pin Finder.
==== log opened: [12/21/2008 5:59:48 PM] ====
Application: C:\Program Files\InfinityBox\PinFinder\PinFinder.exe
Initializing...
software version: 1.14
Smart-Card S/N: 1C2F
Smart-Card firmware version: 0112
Initializing PinFinder...
Initializing database...
base database version: 01
user database version: 01
Loading configuration...
Initializing cable list...
Initializing platforms...
Initialization finished
COM7 ready
searching adapter at COM7...
adapter found, version: 2000
Serial No: 14F4BBB605A0F76303A4B6C42AAC1BDB
done
Initializing...
done
Cable: 2x5 (L10C)
Power On !
cable type: 2x5 (L10C)
platform: MT: MT6205, MT6217-MT6228, MT6230
pins: 10, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
Press and HOLD phone Power button now !
detecting pins...
failed to detect pins
time required: 25 sec
Power Off !
Power On !
pins: 10, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
time required: 40 sec
Power Off !
Power On !
pins: 10, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
error: boot initialization step-2 failed: FD
19200 fixed
CPU: MT6226
result: Rx:5 Tx:4
time required: 20 sec
Power On !
==== log: [12/21/2008 6:13:16 PM] ====
COM7 [VCP0] selected
module  v2.49
Device: Alcatel-OT-C701X, C701A
Checking data, wait...
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A03:8A02]...
CPU: MT6226
chip: 0031:1B7C:A000
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22302200:2BEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.FC226 84A.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V17.BIN_0D326A39].rpl
identification#1 detection finished
device-id: FC22684A
identification#1 protocol ver: 05
ver. sw 1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP  1_V17.BIN
ver. sw 2: MAUI.06A.W06.52.SP1.V17, C695CDF2
ffs offset/size: 01200000/00E00000
detect device identification#2...
detect device identification#2 finished
sim-lock status: disabled
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
original imei: 35320501268468
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
error: wrong answer: A1
error: flash erase error: 01020000
error: flash erase error: 010A0000
error: flash erase error: 01120000
error: flash erase error: 01160000
error: flash erase error: 012E0000
error: flash erase error: 01360000
error: flash erase error: 01500000
error: flash erase error: 01520000
error: flash erase error: 01640000
error: flash erase error: 016C0000
error: flash erase error: 01760000
error: flash erase error: 01880000
error: flash erase error: 01940000
error: flash erase error: 019A0000
error: flash erase error: 01B20000
error: flash erase error: 01B40000
error: flash erase error: 01BA0000
error: flash erase error: 01D00000
error: flash erase error: 01E40000
error: flash erase error: 01E60000
error: flash erase error: 01F40000
error: flash erase error: 01F60000
error: flash erase error: 01FE0000
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_FC22684A_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V17.BIN_0D326A39_20081221-181743.B0X.bin
Finished, time used: 264 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
eventhough it has many ERRORS..
the fone is REPAIRED!
The Following User Says Thank You to 3stanGsm For This Useful Post:
Old 12-21-2008, 13:10   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
Old 12-21-2008, 13:12   #3 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
Great work .......
Faisal_Computer
Last edited by Faisal_Computer; 12-21-2008 at 13:13. Reason: witch i want to post infinity already posted ..
Nokia N900 Auto-Off Done via NSU! yobb Nokia Windows & MeaMo/MeeGo based 0 01-18-2010 14:18
2330c auto off done mquimpanes UFS2 + UFS3-Tornadoflasher 0 11-14-2009 15:43
NEC E101 Auto-off...Done! 3stanGsm Infinity-Box 1 07-24-2008 22:32
Page generated in 0.13741 seconds with 9 queries
