Help Unlock Konka EC003 Try to unlock But Allwes....... COM3 [VCP0] selected module v2.54 Device: Beetel-EC003 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard eeprom backup enabled, it may takes several minutes ! enhanced security fix enabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... slowest Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: STANDARD_PCB01_GSM_MT6205B_DN.KABEC003FM_EN_FR_ES_ 4_01_918.BIN ver. sw 2: KABEC003FM_EN_FR_ES_4.01.918, 00000000 ffs offset/size: 00380000/00080000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[STANDARD_PCB01_GSM_MT6205B_DN.KABEC003FM_EN_FR_ES_ 4_01_918.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[STANDARD_PCB01_GSM_MT6205B_DN.KABEC003FM_EN_FR_ES_ 4_01_918.BIN]_20081221-113517.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data ... detection procedure, wait... error: phone is not locked or unknown eeprom detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Fail Finished, time used: 280 sec Remove/Install battery now ! Ple,hep me to unlock |
Please, select correct model and repeat operation again. |
Thanks ,Thanks You !!!!!!!!!!!!!!!!!!!!!!!!! COM3 [VCP0] selected module v2.54 Device: Konka-EC003 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... slowest Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: STANDARD_PCB01_GSM_MT6205B_DN.KABEC003FM_EN_FR_ES_ 4_01_918.BIN ver. sw 2: KABEC003FM_EN_FR_ES_4.01.918, 00000000 ffs offset/size: 00380000/00080000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[STANDARD_PCB01_GSM_MT6205B_DN.KABEC003FM_EN_FR_ES_ 4_01_918.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[STANDARD_PCB01_GSM_MT6205B_DN.KABEC003FM_EN_FR_ES_ 4_01_918.BIN]_20081221-152357.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting additional parameters... ..... flash: 01227E221A2201:18E59F00000000 flash: 01227E221A2201:18E59F00000000 Write: area 0/1 ........... additional parameters detected Ok Special operation Done Write ... flash: 01227E221A2201:18E59F00000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 316 sec Remove/Install battery now ! ;);););););) |
