help urgent sir i want to unlock motorola c 139 airtel but i cant unlock this i do reser sp lock status and conection working perfectuly Device: C139,C140 Press and HOLD Power button... Connecting, wait... Device connected. Working... current imei: 351975011426499 software version: 1329 MOTOROLA_E88 flex version: FFH_C139_67_Z1C simlock write Ok and i want to unlock this mobile i cant i saw always this meesage Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Err: boot failure[07]: version mismatch, other connection settings should be used. Release Power button ! Connect Fail Finished, time used: 13 sec Remove/Install battery now ! sir plz help me thanks in advance |
Hello, Here is description how to solve this phoblem: http://forum.gsmhosting.com/vbb/show...63&postcount=2 |
@tarunvishal for urgent u can check ur folder in ur pc.. xx\program files\\InfinityBox\Documentation there is many document for solve problem... for ur problem u can read this Infinity-Box_How_to_fix_c115-C139_boot_error_version_mismatch.htm |
hello brother i do everthing bu t plz tell me where softwsre setting |
Hello, good question... let me prepare detailed instruction especially for you, but I need some time... |
Please, read this: http://forum.gsmhosting.com/vbb/showthread.php?t=347240 |
hello sir i also check with com cable but answer is same sir plz help me i have 10 sets for unlocking the phone verison is 1.3.29 and i also try on other computer i always see this message Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Err: boot failure[07]: version mismatch, other connection settings should be used. Release Power button ! Connect Fail Finished, time used: 19 sec Remove/Install battery now ! |
@tarunvishal sad to say, but looks like you have big problems with reading. Here is final info for you, my lazy friend. go to "Settings" page in software. select connection mode v4 repeat unlock process thread closed due to no reasons to continue. |
