07-04-2007, 13:43 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | A38 in-comming lock ! thanks to INFINITY. i solved my problem A38 in-comming lock with INFINITY. just flash eeprom. here is log................... COM4 selected Device: BenQ A38 Checking data, wait... Action: Flash write Smart Write active Skip: Firmware Skip: Flex Skip: Language Pack Write: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E221D2200 flash: Amd S29GL032A-U r1,r2,r8,r9 U 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Eeprom Flash: 0001:227E221D2200 flash: Amd S29GL032A-U r1,r2,r8,r9 U 4Mb Writing Done Finished, time used: 29 sec Remove/Install battery now ! |
Phones that have build in COM emulation - help, it is easy | bandaska | Chinese Models & Cloned Phones | 12 | 11-12-2009 22:54 |
6230i low sound when in comming call | obyy | Nokia Hardware & Hardware Repair | 1 | 01-05-2008 21:39 |
6230i no sound when in comming call | phonicator | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 08-16-2007 10:27 |
strange problem in com port the box | CONTACT-GSM | FuriouS II | 9 | 07-12-2005 22:40 |
