Old 02-16-2021, 12:11   #1 (permalink)
Member: 2095478
Thanks Meter: 49
Help With Wiko W-V800 Tested Firmware.
Hello Everyone. Please i need help about Wiko W-V800 Retail mode (Demo) problem. The phone has Password in "setting" and can't install any apk, even after hard reset or format by CM2SP2. I think i can solve this problem by flashing the phone with another firmware, I heve tried this firmware from easy-firmware ''W-V800-EEA-V01.41-20-9.0-GBL" but the phone dead after falsh the firmware, luckily i have readed its original firmware before flashing it. Now the phone is in Retail mode as it is before. So i need some guide to remove DEMO if there is,or Tested firmware to flash the phone and see if it can solve my problem. Thanks
Old 02-16-2021, 12:53   #2 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Good, you enter recovery mode, wipe data factory reset, when the mobile starts, you select the corresponding language and the next screen that will appear there is a kind of gear, you press it until a submenu appears and there you can deactivate the retail mode demo of wiko, we make the necessary adjustments until we reach the wiko home screen, the next thing is to activate the developer mode, we connect the mobile with the usb cable to the computer, we check that the drivers have been installed correctly and especially the adb driver, we open cmd and write the following command:
adb shell cmd package unistall -k --user 0 com.ape.retailmode
The Following 3 Users Say Thank You to Franky_36 For This Useful Post:
Old 02-17-2021, 11:42   #3 (permalink)
Member: 2095478
Thanks Meter: 49
Thank you sir, i've got it done.
Page generated in 0.14017 seconds with 8 queries
