Old 10-29-2015, 04:35   #1 (permalink)
Member: 651892
Thanks Meter: 205
Lenovo A390 Simlock
as cm2 says mt6575/6577 unlock not support
is it possible to unlock this phone?
Operation : Read NVRAM [ v1.35 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8B00
BB_CPU_SB : E201
BB_CPU_NM : [MediaTek] MT6575|MT6577_S00
Processing BROM stage
i2c Init : 0300771F
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
DA Stat : v3.2 on BBID : 0x84
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : HYNIX
[eMMC] : FLASH_CID : 90014A2058494E594816A1000D264047
[eMMC] : FLASH_EXT : 00200000/00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[Info] : BaseBand : MT6577_S00_MAUI_11AMD_W12_22_SP_V21_P9
Read Ok, MT6577_S00_MAUI_11AMD_W12_22_SP_V21_P9_eMMC.spnv saved
Done!
Elapsed: 00:00:21
Reconnect Power/Cable!
Operation : SP Unlock [ v1.35 ]
Mode : Read Codes
Wait for phone...
Phone found! [ 6 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8B00
BB_CPU_SB : E201
i2c Init : 0300771F
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Error : MT6575/MT6577 not supported!!!
Done!
Elapsed: 00:00:10
Mode : Direct Unlock
Wait for phone...
Phone found! [ 6 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8B00
BB_CPU_SB : E201
i2c Init : 0300771F
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:12
if need dump file..will be uploaded
Here is nv backup if its help
Old 10-29-2015, 07:56   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello, will check it and try make something. But not sure.
The Following User Says Thank You to JayDi For This Useful Post:
Page generated in 0.13052 seconds with 9 queries
