Hi Everybody!!!! I have a pantech pg-1410 from argentina, and i can`t change imei of this phones, somebody can?; if yes please tell me how Thank You very much!!!! |
Hello, Did you tried to use Infinity-Box for imei repair ? |
Yes ... I tried to change imei with infinity-box the software tell me that the change was sucsessfull but i see the imei on phone and it shows the same ... Very Strange problem :confused: Can you Help me ? Thank You very much !!! |
Hello, Post log here so we can check details |
Here is the log friend COM40 [VCP0] selected Device: Pantech PG-1410 Checking data, wait... Action: imei repair Boot... Phone must be POWERED-OFF ! Cable must be in "GPRS" mode ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:0CE59F00000000 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb id: 0000527A Boot Done Set baud... 921600 Set baud Done Check flash... Check flash Done Check space... file saved: C:\Archivos de programa\InfinityBox\PNModule\backup__eeprom_Pante ch PG-1410_20080613-134744.8FE.bin Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Finished, time used: 16 sec Remove/Install battery now ! After this the phone shows Original imei |
Try to change only last 5 digits |
Exactily the same I have bloqued in the program the first numbers of the imei, also y changed the last 5 numbers but the same imei on phone, the imei on phone starts by 0106 i´m trying reseting all, if you have other suggestions please tell me Thank You !!!!! |
i reseted the phone now the imei phone shows 010676000010000 but the phone don`t make calls i think this imei is back listed, but i try to change it again and after this the imei it`s the same :confused: I don`t now what to do Thank You for the help ! |
So finally imei was written, right ? |
Yes But... The Soft changed the imei to the phone but i tried write imei to other phone and it wrote again the same imei no the imei that i wrote on the soft... The imei that the 2 phones show is this 010676000010000 |
Hello, try to write the same ime as at phone back label but make only last 5 digits different |
i can`t The software has blocked the 8 first numbers of imei, i can`t change them on the soft |
Sorry, but I did not understand. What was original imei ? What is current imei ? What you have tried to do ? What you need to do ? |
Well i explain all I have phones pantech pg-1410 from Argentina All this phones imei starts by 01091500******* When i try to change imei the software say to my that the imei was changed with the imei that i wrote on the soft like this 35734400******* but when i see the phone´s imei it shows 010676000010000 and this imei is backlisted, i tried with 5 phones and in all happen the same thing .... Here is other log : COM40 [VCP0] selected Device: Pantech PG-1410 Checking data, wait... Action: imei repair Boot... Phone must be POWERED-OFF ! Cable must be in "GPRS" mode ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:0CE59F00000000 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check flash... Check flash Done Check space... file saved: C:\Archivos de programa\InfinityBox\PNModule\backup__eeprom_Pante ch PG-1410_20080618-121436.8FE.bin Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Finished, time used: 26 sec Remove/Install battery now ! Thanks ! |
Good day ! Try to write 5 last digits, not first |
