12-18-2008, 17:31 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: Sweden
Member: 503620 Status: Offline Sonork: 1621694 Thanks Meter: 46 | hi infinity team help me |
12-18-2008, 18:07 | #2 (permalink) | |
The most expensive part of box is "smart-card". Open box and you will see white color sim-card, it's a smart-card. You can insert this smart-car in other box (f.e. SE-Tool etc.) or you can buy external e-gate card-reader (contact your reseller, for sure he must know what is it). Estimated card-reader price is 10-15 usd (maybe even cheaper). Then you will be able to run Infinity-Box software and you can use any cables set instead of damaged Infinity-Box unibox. | |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
12-31-2008, 16:07 | #3 (permalink) | |
Member: 503620 Status: Offline Sonork: 1621694 Thanks Meter: 46 | Quote:
sir i purchased external egate card reader but there is one confusion i paste infinity smart card in external egate card reader but whice box i do attach for use infinity software bcoze my infinity box crashed,dead bcoze when i try to start infinity setup soft it says box not found... help | |
12-31-2008, 16:32 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Remove card-reader from PC Open PC Device Manager Connect card-reader (with card inserted) to PC Do you see new device (e-gate smart-card) in Devicemanager when you connect card-reader (with card) to PC ? Also, if you have other box with e-gate smart-card (f.e. SE-Tool), you can insert Infinity-Box smart-card in this box and test is it possible or not to run Infinity-Box software. |
12-31-2008, 17:06 | #5 (permalink) | |
12-31-2008, 18:13 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If so it may be card-reader fault or smart-card become damaged. If you have Se-Tool or other boxes try to check "e-gate smart card" device with other box. If you will be able to see "smart-card" device with other box then you have a reason to insert Infinity card in other box and see results, so we will know for sure where is the problem: is it card-reader fault or smart-card fault. |
12-31-2008, 18:54 | #10 (permalink) | |
No Life Poster Join Date: Jun 2001 Location: Dubai, UAE
Member: 4929 Status: Online Sonork: 100.37251 Thanks Meter: 238 | Quote:
the above post is one of the up**** examples.....Infinity undoubtly the BEST support ever. I envy you | |
The Following User Says Thank You to Hams For This Useful Post: |
12-31-2008, 19:04 | #11 (permalink) | |
01-01-2009, 13:59 | #14 (permalink) | |
i paste infinity smart sim to nspro box now software being open but tell whice com i have to select usb com or nspro com ...?bcoze i tried many phones that were not detected. | |
Infinity can't unlock MXNEC N9 chip Infineon 7880, Infinity team help me ! | coolderheart | Infinity-Box | 1 | 11-15-2009 06:12 |
Hi spiderman team help me | uzmantel | SpiderMan | 1 | 11-10-2009 08:11 |
hi infinity team help me out | robin25 | Infinity-Box | 2 | 07-02-2009 17:25 |
hi gsm team help me.. | sood | Nokia Hardware & Hardware Repair | 6 | 08-12-2008 08:09 |
infinity team help me | jmustufa | Infinity-Box | 1 | 03-21-2007 11:20 |
