01-27-2011, 14:54
#1 (permalink)
Member: 779665
Sonork: 100.1581784 Thanks Meter: 492 | Hi mobile locked to ballen naderland unlock problem Hi infinity team i have one Mtk6225 Quote:
Hi compny mobile locked to bellen Naderland
| i tried every thing but couldnt sucsessfull here is UNLOCK OPRATION Quote:
COM14 [VCP0] selected
module v3.08
Action: read unlock codes
unlock method: read codes
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:9A03:000B
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: T500.DUTCH.PR.R0.2_V8.0
Version: TINNO25_08A_GEMINI_HW
detecting structure #2...
1 2 3 5 7 8 9 11 13 done
80 byte(s) read
imei: 35868800000015
connection Ok
detecting structure #1...
0 2 3 4 7 9 12 13 14 15 16 18 19 20 23 25 28 29 30 31error: detection failed (20 tries), read flash and send to support
error: can't read required data
error: operation failed !
Finished, time used: 13 sec
Remove/Install battery now !
| Formate ffs Quote:
module v3.08
Device: Autodetect 6205-6227 NOR
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 01227E223C2200:0AEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
otp offset: 00000000
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA
total flash region size: 02000000
usb bootloader detect...
usb bootloader (chip) is present: 00010000
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info ver: 05
sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.T500_DUTC H_PR_R0_2_V8_0.BIN
project-id: T500.DUTCH.PR.R0.2_V8.0, 00000000
code offset: 00010000
ffs offset/size [01]: 01C00000/00400000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 01C00000
standard ffs/eeprom offset confirmed: 01C00000
detecting ffs/eeprom size...
ffs/eeprom size: 00400000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:01C00000-01FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.T500_DUTC H_PR_R0_2_V8_0__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\TINNO25_08A_GEMIN I_PCB01_GPRS_MT6225_S00.T500_DUTCH_PR_R0_2_V8_0__f fs_20110127-174235.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 21 min 3 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
| I readed flash back up too ill upload when ****ing complete thanks |
