Old 11-12-2007, 16:49   #1 (permalink)
kevin168's Avatar
Member: 183921
Sonork: 100.1590817
Thanks Meter: 205
why i can't connect this phone??
i have try pin out available in This forum..
but that didn't workin..
i have N73 China Copy with DKU-2 conector..
i have tried this pin out, but won't connect
[IMG][/IMG]
can anyone give me another pin out???
br,
kevin168
Old 11-12-2007, 17:00   #2 (permalink)
kevin168's Avatar
Member: 183921
Sonork: 100.1590817
Thanks Meter: 205
i found ground was different...
br,
kevin168
Old 11-12-2007, 20:53   #3 (permalink)
kevin168's Avatar
Member: 183921
Sonork: 100.1590817
Thanks Meter: 205
nobody can answer or give me some advice to search testpoint???
br,
kevin168
Old 11-12-2007, 21:04   #4 (permalink)
Member: 493279
Thanks Meter: 12
These phones are all headaches don't waste your precious time on chineses miracles. Ockiya
Old 11-12-2007, 21:33   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Due to a lot of different models with the same name but absolutely different hardware,
bottom connectors and different pinouts we recommend you to include the next info:
1. detailed description of model
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, check the next detailed description how to get pinout for your model:
use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
Old 11-13-2007, 16:11   #6 (permalink)
kevin168's Avatar
Member: 183921
Sonork: 100.1590817
Thanks Meter: 205
yeah i'll give u the info, please make some good answer, not just same answer always like that,
1. Chinese Phone Similiar with N73 with DKU-2 connector like the original ones
2. MT6226BA CPU id
3. I'll give u already Phone PCB picture, sorry for bad quality
4. I think i didn't need to attach, just same like N73
5. Bottom, was same like the original, i can plug Original DKU-2 cable into this connector
6. i'll give u the phone Ground and Vcharge
and about the hint that u tell us when we search all the pinout, i already try it, try one by one to find right TX and RX.
but actually i cant find it yet.
br,
kevin168
Old 11-13-2007, 16:17   #7 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
will, i guess no one can give you a clear answer unless he/she tested this kind of board and found pinouts
but my advice to you, after you found GND and PWR you have 8 pins left to test
power on the phone and test the lines which give 2.7-2.8v
or 1.6-1.7v these should be the Rx Tx lines, you need to search for diffrent combinations after you find the lines with voltages i mentioned.
hope its helpfule information
Mansi
Old 11-13-2007, 18:44   #8 (permalink)
kevin168's Avatar
Member: 183921
Sonork: 100.1590817
Thanks Meter: 205
i had already found the pin out for my phone.
there is the pic..
i also send full backup data and upload in rapidshare,
please check it infinity team,
http://rapidshare.com/files/69466527...33_newCopy.rar
br,
kevin168
Old 11-14-2007, 00:12   #9 (permalink)
kevin168's Avatar
Member: 183921
Sonork: 100.1590817
Thanks Meter: 205
COM9 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: read eeprom
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:2AEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device parameters autodetection in progress..
total flash region size: 01000000
detect device identification, method #1...
detection phase #1...
detect device parameters finished
structure: 2nd [enhanced] (or higher) generation
identification data Ok
identification data backup saved: id.1E1E4B98.[D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN_8532 097B].rpl
New firmware detected: D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN
- make "Read detailed information, ask/rpl" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
identification detection finished
device-id: 1E1E4B98
protocol ver: 04
ver. sw1: D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN
ver. sw2: D421_V1.00
ffs offset/size: 00E00000/00200000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
eeprom found near: 00E00000
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area: 00000000:00E00000-00FFFFFF
reading [eeprom[D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN]_20071113-230006.B0E.bin
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _1E1E4B98_D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_0 0.BIN_8532097B_20071113-230012.B0X.bin
Finished, time used: 73 sec
Remove/Install battery now !
Old 11-14-2007, 00:13   #10 (permalink)
kevin168's Avatar
Member: 183921
Sonork: 100.1590817
Thanks Meter: 205
Action: read information
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6226, E02
Hardware version: D421_05C_HW
Software version: D421_V1.00"
Software date: 2005.04.12
Barcode: 081701MT012345678901235432
imei: 35640601620xxxx
Finished, time used: 23 sec
Power off phone now !
Old 11-14-2007, 00:15   #11 (permalink)
kevin168's Avatar
Member: 183921
Sonork: 100.1590817
Thanks Meter: 205
Action: read/check detailed information
Boot...
19200
Connecting, wait...
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device-id: 1E1E4B98
protocol ver: 04
eeprom chip: 00
detection phase #3...
done
detecting structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
eeprom element #1 detected ok
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _1E1E4B98_D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_0 0.BIN_8532097B_20071113-231006.B0X.bin
Finished, time used: 61 sec
Old 11-14-2007, 00:16   #12 (permalink)
kevin168's Avatar
Member: 183921
Sonork: 100.1590817
Thanks Meter: 205
Action: read NOR flash
Boot...
19200
Connecting, wait...
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device-id: 1E1E4B98
protocol ver: 04
eeprom chip: 00
reading [flash[D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_flash[D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN]_20071113-231510.B0M.bin
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _1E1E4B98_D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_0 0.BIN_8532097B_20071113-231635.B0X.bin
Finished, time used: 345 sec
Old 11-14-2007, 16:41   #13 (permalink)
Member: 130995
@kevin168
Thank you very much for info and files !
Old 11-14-2007, 19:31   #14 (permalink)
kevin168's Avatar
Member: 183921
Sonork: 100.1590817
Thanks Meter: 205
yes phone was restarting at the first now all was OK when do Format FFS job, and write the Imei,
nice job from Infinity, but still tired when search for new Pinout.
br,
kevin168
Old 11-14-2007, 21:51   #15 (permalink)
DarkManDZ's Avatar
Member: 431529
Thanks Meter: 18
HI ALL
i have trouble with this model of N73
it s a copy of nokia n73 but rh64 i cant find its pinouts
please help
2. MT6226BA CPU id
PRODUCT IMAGE AT http://rapidshare.com/files/69737669/N73_RH64.JPG
THANX
why i can't unlock this n91 nyong NoooX Box 2 10-25-2008 19:38
why ustpro can't unlock this poor phone c180 long way UST Pro II 2 10-03-2008 10:03
((( why i can't connect J100 with infinity ))) Faisal_Computer Infinity-Box 10 04-30-2007 10:04
LG 5300 why i can't Connect my Phone ?? newland LG 2 08-05-2003 17:28
Page generated in 0.40276 seconds with 10 queries
