04-26-2017, 20:38 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Infinity cm2 successful stories by yuslam unique ventures READ INFO LOG Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E4361726420434F30815683E7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E4361726420434F30815683E7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB] DEV RID : 0xDEC55C371051D298CB5FB0AC45B59B97 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : ZTE ProdName : E7L ProdModel : E7L Device : E7L AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_ELINK8321.EMMC_P41 SECURITY : IMEI_SW [1] : 867314013081366 IMEI_SW [2] : 867314013081374 BTMAC Addr : 54EF92AFDCFD WiFi MAC : 54EF9265761B MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P2_1_wg_n EXTRA : LCD : Not info available :( LCD Res : 600x1024 TOUCH [0] : GSLX688 CAM [0] : sp2509_mipi_raw CAM [1] : sp0a09_mipi_raw CAM [2] : ov5648_mipi_raw CAM [3] : gc5024_mipi_raw CAM [4] : gc5004_mipi_raw CAM [5] : gc2355_mipi_raw CAM [6] : gc2235_mipi_raw CAM [7] : gc2145_mipi_yuv CAM [8] : gc2155_mipi_yuv CAM [9] : gc2755_mipi_raw CAM [10] : gc0310_mipi_yuv CAM [11] : ov2680_mipi_raw CAM [12] : hm03d5_mipi_yuv MODEM : elink8321_hspa_tb_W4 LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:10 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E4361726420434F30815683E7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E4361726420434F30815683E7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB] DEV RID : 0xDEC55C371051D298CB5FB0AC45B59B97 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : ZTE ProdName : E7L ProdModel : E7L Device : E7L AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_ELINK8321.EMMC_P41 [Read Ok] : preloader_elink8321_emmc.bin [Read Ok] : items.img [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / elink8321_emmc / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1425 MiB Scatter saved to : C:\Users\Yuslam Unique\Desktop\SP Backup\MT6580__ZTE__E7L__E7L__5.1__ALPS.L1.MP6.V2_ELINK8321.EMMC_P41\ All done! Done! Elapsed: 00:09:36 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to Yusuf Lawal For This Useful Post: |
05-16-2017, 22:10 | #4 (permalink) |
Junior Member Join Date: May 2017 Location: Abuja, Nigeria
Member: 2717819 Status: Offline Thanks Meter: 1 | My problem is if I install the dongle there show me email and password but if I but it I can receive Message in my email but no de work pls solve the problem for me Sent from my P5 mini using Tapatalk |
05-20-2017, 09:40 | #6 (permalink) |
No Life Poster Join Date: Apr 2014 Location: west java
Member: 2162000 Status: Offline Sonork: 100.1670061 Thanks Meter: 205 | |
The Following 2 Users Say Thank You to solusi hp For This Useful Post: |
05-20-2017, 12:58 | #7 (permalink) | |
Freak Poster Join Date: Mar 2009 Location: Pakistan
Member: 1000101 Status: Offline Thanks Meter: 13 | one story by me huawei y5ii try frp reset but procces not success.phone dead here log Quote: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 110100303038473730001954A2F973A5 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! | |
05-27-2017, 15:31 | #9 (permalink) | |
Posts have been moved to correct thread - http://forum.gsmhosting.com/vbb/f296...ty-box-725574/ Please in future use special thread for test report - http://forum.gsmhosting.com/vbb/f296...ty-box-725574/ Thank you ! | |
05-27-2017, 15:38 | #10 (permalink) | |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
