01-09-2017, 14:02 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: South Africa/Pakistan Age: 44
Member: 476940 Status: Offline Thanks Meter: 57 | Hisense F20 Flashing Failed Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Hisense Device Manufact.: Hisense Device Model : HS8909QC Device CPU : MSM8909 Device IntName : F20AE-1 Device Version : 5.1.1 CU_SWVer : Hisense Device Compile : 9/19/2016 8:48:48 AM Device Project : L1236.6.01.03.ZA04 Device ExtInfo : Hisense F20 Load Ok! Operation : Flash [ v1.06 ] Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 04B32785 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 02E29866D15D4A452217F9E62178F8D0 ID_BLOCK_L : 6EE5AB02F79EC04578B718D1D3D2CC0F Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001C3000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Files in Chain : 29 Flashing now Flashing : gpt_main0.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : misc.img Flashing : lsplash.img Flashing : NON-HLOS.bin Flashing : sec.dat Flashing : boot.img Flashing : system.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : userdata.img ProgStart : Parsed value exceeds size of partition in sectors Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! |
01-16-2017, 12:17 | #2 (permalink) | |
Insane Poster Join Date: Mar 2010 Location: indonesia
Member: 1270521 Status: Offline Thanks Meter: 21 | Hisense F20 Flashing Failed Quote:
what u use bootkey to enter on edl mode ? i use edl cable but not work. if i can conect mybe i can backup my room, and you can try flashing with my backup room | |
06-10-2017, 06:06 | #6 (permalink) |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Press and hold VOL DOWN key,Connect EDL cable to device,Release EDL cable switch.It should go to EDL mode after it.You can release now VOL DOWN key My little help to all forum users BR. Sehar GPG Team |
The Following 6 Users Say Thank You to ij_cell For This Useful Post: |
10-13-2017, 16:30 | #7 (permalink) |
Banned Join Date: Jun 2008 Location: Algérie
Member: 784101 Status: Offline Sonork: 92737 Thanks Meter: 39 | no need to use test point easy way, _on battery cover the BSI line(Center between positive and negative) _insert battery and back cover _Press vol up and volume down _Insert EDL cable with switch pressed _then release switch while still holding vol up and down _Device will be detected in Qualcomm mode Please test and report. |
The Following User Says Thank You to george k For This Useful Post: |
10-14-2017, 05:34 | #8 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2047358 Status: Offline Thanks Meter: 0 | Work with mtk? Hey guys good day! I just wanted to ask if edl cable can be use with mediatek devices? I have xbo v11 but everytime i connect the device to my laptop via usb cable it always says "usb not recognized. The last usb connected to this pc are malfunctioned" can i use edl cable so that my pc will detect nd installed driver for my deice so i can flash firmware via sp flash tool..pls guide me on this..newbie here thank you |
