10-20-2016, 15:48 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | hmobile b61 rda dead after format problem-busy on incoming call format done result set dead Code: Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4009 CPU_CN : RDA Micro CT , RDA8851X ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 8809 , 00400000 Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C058F4 , 81C05908 CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:01:09 Reconnect Power/Cable! Code: Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4009 CPU_CN : RDA Micro CT , RDA8851X ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 8809 , 00400000 Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... Target BbCpu : CT88X9 Target Flash : flsh_spi32m Project Name : FR_AR_S_GC6133_V17_0606 Project Info : 88X9_QQVGA_K5115 [BIN] Saved as : FR_AR_S_GC6133_V17_0606_88X9_QQVGA_K5115_CT88X9_flsh_spi32m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\FR_AR_S_GC6133_V17_0606_88X9_QQVGA_K5115_CT88X9_flsh_spi32m.iff [CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\FR_AR_S_GC6133_V17_0606_88X9_QQVGA_K5115_CT88X9_flsh_spi32m.ifc Build done Done Elapsed: 00:18:26 Reconnect Power/Cable! |
