Hotwave cosmos v19 plus not supported read info and read flash Hotwave cosmos v19 plus
android version 6.0
build number:
S7358_hwd_v19_plus_hotwav_1288_hd_band_vo1.01b03 Quote:
chinese miracle ii [spd module] v 1.27
set mode to : Sp [sc773x] emmc [android 6.x]
start at : [8/8/2017 / 9:54:33 am]
operation : Check/read info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'volumeup' and 'volumedown' keys
-> alternative : Just one 'volumeup' or 'volumedown' key
3. Insert cable
==== wait for phone...
Phone found! [ 9 ]
port opened
sync...
Initboot done [ 0x81 ] , ver : Sprd3
sync...
Sending fdl
[info] : If sw freeze here more, than 15 seconds - remove cable
boot failed!
Ds : Loader start failed! Wrong model selection!
Boot failed!
Reconnect power/cable!
| Quote:
set mode to : Sp [sc773x] emmc [android 5.x]
set mode to : [altldr] sp [sc773x] emmc [android 5.x]
start at : [8/8/2017 / 9:55:28 am]
3. Insert cable
Phone found! [ 9 ]
port opened
sync...
sync...
Sending fdl
fdl ready!
Boot ver : Sprd 773x emmc loader v4 infinity
sending flash fdl
flash fdl ready!
Boot ok!
Unknown structure detected! Check correct model selection!
Elapsed: 00:00:26
reconnect power/cable!
| Quote:
set mode to : [altldr] sp [sc773x] emmc [android 6.x]
start at : [8/8/2017 / 10:09:07 am]
3. Insert cable
Phone found! [ 9 ]
port opened
sync...
sync...
Sending fdl
boot failed!
Boot failed!
Reconnect power/cable! | reset via svc ok Quote:
start at : [8/8/2017 / 10:05:34 am]
operation : Format file system / reset settings [ v1.27 ]
settings : Smartformat is on
2. Insert cable
3. In case of svc init problems - connect with hold "voldown" button!
Phone found! [ 9 ]
port opened
sync...
Initsvc done
wait for phone...
Sync...
Init ok , reset settings ...
Format ok!
Done
elapsed: 00:00:24
