Old 06-06-2009, 04:49   #1 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
Usha-lexus 858b new firmware decetted
USHA-LEXUS 858B NEW FIRMWARE DECETTED
HEARE IS LOG:-
COM2 [VCP0] selected
module v2.82
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:5303:000D
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22202200:2AEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.8EDD0034.[LCBJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.BIN_CED040EB].rpl
New firmware detected (v.2.82, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup files to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 8EDD0034
identification#1 protocol ver: 04
ver. sw 1: LCBJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.BIN
ver. sw 2: LB1UI01.6.3.1.2T18M0428_M501B, 14BF2F31
ffs offset/size: 00C00000/00400000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00C00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00CC0000
Detected ffs/eeprom address is non-standard: 00CC0000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00CC0000
detecting ffs/eeprom size...
ffs/eeprom size: 00340000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00CC0000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: LCBJ25_07A_PMJ_PCB01_GPRS_MT6225_S00__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\LCBJ25_07A_PMJ_PC B01_GPRS_MT6225_S00__ffs_20090606-091515.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\L CBJ25_07A_PMJ_PCB01_GPRS_MT6225_S00__system_log_8E DD0034_CED040EB_20090606-091633.B0X.bin
Finished, time used: 211 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
CAN I FLASH OTHER FILE?
The Following User Says Thank You to debmobile For This Useful Post:
Old 06-06-2009, 06:02   #2 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
HEARE IS LOG:-
module v2.82
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
device-id: 8EDD0034
Posible reasons:
ffs/eeprom chip: 00
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
what is actual problem with phone????
is it dead?? than flash with other firmware from support area
if its turning on than u can try safe mode format ffs
The Following User Says Thank You to deepakgarg For This Useful Post:
Old 06-06-2009, 15:46   #3 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
yes set is dead when i format safe mode.not complite mode. thanks.....
Old 06-06-2009, 15:59   #4 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
try to write back backup..
or
new phone USHA LEXUS 303B READED OK ON INFINIITY. debmobile Infinity-Box 3 03-20-2010 16:29
usha lexus 877B NEW FIRMWARE >>>>> debmobile Infinity-Box 0 02-11-2010 06:46
plese anybody share usha-lexus 858b good readed file??? debmobile Chinese Models & Cloned Phones 0 06-07-2009 21:25
Can anybody help usha-lexus 858b good readed file debmobile Infinity-Box 2 06-07-2009 04:35
usha-lexus pinout need rajeshbahri Infinity-Box 9 09-09-2008 09:26
Page generated in 0.24937 seconds with 10 queries
