05-27-2010, 13:43 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | how to change slave imei on china mobiles pls help any boddy know the procedure of persion post me |
05-29-2010, 06:45 | #7 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | yes i did that but when i check manually *#06# i will show on display example : MASTER IMEI: 357988022071992 SLAVE IMEI : 135790246811220 PLS CHECK MY POST RESULT BELOW COM3 [VCP0] selected module v3.14 Action: "repair imei" imei write method: mode-2 imei write channel: imei #2 for dual sim/mono CPU new imei: 357988022071992 Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:927C:74AB status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: RHINO_6226_CKT_L8EN_208_080402_LD0_0V0_SA75_CTF_BT _FM_TV Version: SWAN_6226 detecting structure #2... 0 done 44 byte(s) read imei: 35659800341909 connection Ok detecting structure #2... 0 done 44 byte(s) read verification... verification done: 35798802207199 Finished, time used: 17 sec Remove/Install battery now ! HOW CAN DO WRITE IMEI SLAVE NOW PLS TELL ME SIR |
05-29-2010, 11:51 | #8 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | COM3 [VCP0] selected module v3.14 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:927C:74AB status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B426F842.[CKT26_06B_RHINO_10A_PCB01_GPRS_MT6226_S01.RHINO_62 26_CKT_L8EN_208_080402_LD0_0V0_SA75_CTF_BT_FM_TV.B IN_1C3F7C75].rpl rom info detection finished ==================== New firmware detected (v.3.14, database date: 28.05.2010): CKT26_06B_RHINO_10A_PCB01_GPRS_MT6226_S01.RHINO_62 26_CKT_L8EN_208_080402_LD0_0V0_SA75_CTF_BT_FM_TV.B IN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: B426F842 rom info ver: 04 sw version: CKT26_06B_RHINO_10A_PCB01_GPRS_MT6226_S01.RHINO_62 26_CKT_L8EN_208_080402_LD0_0V0_SA75_CTF_BT_FM_TV.B IN project-id: RHINO_6226_CKT_L8EN_208_080402_LD0_0V0_SA75_CTF_BT _FM_TV, 757C3F1C code offset: 00000000 ffs offset/size [01]: 00F00000/00100000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00F00000 standard ffs/eeprom offset confirmed: 00F00000 detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00F00000-00FFFFFF detecting ffs/eeprom structure pass 1... ..................... ffs/eeprom: detect standard location pass #1... .................................................. .......... ffs/eeprom: detect extended location pass #1... .................................................. ... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: CKT26_06B_RHINO_10A_PCB01_GPRS_MT6226_S01.RHINO_62 26_CKT_L8EN_208_ detecting firmware build... .................................................. ... firmware build: L8EN_208_080402_LD0_0V0_SA75_CTF_BT_FM_TVSWAN_6226 2008-04-0220-00 detecting product-id... .................................................. .............. done detecting languages... ........................................... language parameters detected detected languages: En Ru Fr Id Vn Tr Farsi Ar file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\C KT26_06B_RHINO_10A_PCB01_GPRS_MT6226_S01.RHINO_622 6_CKT_L8EN_208___system_log_B426F842_1C3F7C75_2010 0529-161806.B0X.bin Finished, time used: 2 min 18 sec Remove/Install battery now ! this is our full read info of that mobile |
05-29-2010, 12:09 | #9 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Zonguldak, Turkey Age: 55
Member: 56619 Status: Offline Thanks Meter: 62 | are u sure that it has single cpu. I think it has two cpu. one is 6226 and the other is 6205. so you must select correct pins for the second cpu |
The Following User Says Thank You to krace For This Useful Post: |
05-30-2010, 10:21 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! mr. krace is absolutely correct. 6226 MCU always has second (slave) CPU find its pinout, that MCU is 6205 and change IMEI in it, using option IMEI#1 |
05-31-2010, 07:42 | #11 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | yes it has two cpu on that bcp. one is (arm mt6226ba)another one is (mt6305b)how to connect secound cpu (mt6305b) pin because more pinout are in this pcb (gnd,pwer3,pwr6,rx6,tx6,tx_bt,rx_bt,tx3,rx3.)which pin out will i take for this secound cpu? pls help me |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
