06-24-2015, 06:06 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Karbonn a99i hang on logo Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.21 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 96 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447581068510C5145 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D43303447581068510C5145 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : kphone72_wet_jb3 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002300000-0x0000000094840000 Flash Pre-Erase Done, time used : 00:00:06 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_kphone72_wet_jb3.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Write Error! Something went wrong! Done! Elapsed: 00:02:25 Reconnect Power/Cable! set was hang on log when try wipe with keys its show mount error when try read flash file it give error at system file read like file unusable so i try to flash with og file and give me at this stage error but after this error also work fine my set and set alive and all ok but want to know y this error and after error how set alive and ok ? btwn i am happy my set ok |
06-24-2015, 09:08 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Seems as eMMC going to die, or some other fault. Error change not much , but check internal SD state - it must have some free space and must working. |
