03-07-2018, 17:08 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: africa mali
Member: 2098907 Status: Offline Thanks Meter: 154 | Qlcom frp unlock failed Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 94612D77 ID_BLOCK_E : 2016A239 ID_BLOCK_L : 6DFD0376A49B6C2B073AA7152D039535 ID_BLOCK_L : E05A4006C55252373ACF8A64F6F8E3DA Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
03-09-2018, 19:08 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | QBOOTv116.zip ? RGhost ? ????????????? Put files from archive to CM2QLM/Boot/ folder with change old files. Restart module and repeat operations. I put loaders for both version of this device ( low and mid ) on 430 and 425 chipsets. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
03-10-2018, 09:58 | #10 (permalink) |
Member: 2098907 Status: Offline Thanks Meter: 154 | thnx to MR jaydi frp unlock done Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 94612D77 ID_BLOCK_E : 2016A239 ID_BLOCK_L : 6DFD0376A49B6C2B073AA7152D039535 ID_BLOCK_L : E05A4006C55252373ACF8A64F6F8E3DA Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QX13MB Boot Ok! Remove FRP Reset Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:49 Reconnect Power/Cable! |
The Following User Says Thank You to goudio For This Useful Post: |
09-04-2019, 10:42 | #12 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Here is new link- https://drive.google.com/open?id=14D...DuDnvb4vaXlTHZ Br. Infinity-Box Team. |
09-04-2019, 11:17 | #13 (permalink) | |
No Life Poster Join Date: May 2008 Location: On your Key-board Age: 37
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | Quote:
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : EB250452 ID_BLOCK_E : 2016A239 ID_BLOCK_L : 3698262DC1C00150DC17C0704028BE6E ID_BLOCK_L : 24868CC219969EF3E60B4EA03A342706 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! | |
The Following User Says Thank You to dyo For This Useful Post: |
