how to extract contacts Good day! when reading contacts fails. How to solve a problem? |
Hello, Where is log/screenshot? Br. |
Log will be enough completely. |
Chinese Miracle II [MTK module] v 1.35 Operation : Check / Read Info [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 16 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 77D57F0424B67128C031A91201EB557C BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 1800 0000 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 SDS_INFO : Not exists Processiung : PhoneBook extraction Step #1 Step #2 Error! Seems as unknown type! Send DUMP + Report to support! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable![/CODE] |
Read FlashDump and upload somewhere. Send me link after. |
What model type is this?? it might be Nokia original |
