Old 06-26-2020, 20:35   #1 (permalink)
Member: 148515
Thanks Meter: 19,534
How to fix CM2 Software can not run
Alternative manual is HERE
If Infinity software can not run or exit silently or disappear it means your PC should be configured well for your work.
1. Disable AVAST | Windows Defender | Other antivirus
2. Cure your PC with free Antivirus - https://free.drweb.com/download+cureit+free/?lng=en
If software files was damaged by virus - delete C:/InfinityBox/CM2MT2/ or /CM2SP2/ or /BEST2/ software folder completely and reinstall it.
3. Uninstall or Disable sharing tools like Flexihub, virtualhere, teamviewer, anydesk and similar
Probably you should delete spy Flexihub files manually and Reboot PC after that
c:\windows\system32\ftusbsrv.exe
and probably the next:
c:\windows\system32\fusbhub.sys
c:\windows\system32\vuhub.sys
c:\windows\system32\eusbstub.sys
c:\windows\system32\evsbc9.sys
c:\windows\system32\evserial9.sys
4. In case of Misconfiguration run DongleManager and make (1) and (2) and after that click to link (3) for info
5. If problem still exist run Process Explorer
Go to menu File -> Save and copy/paste text here
The Following 28 Users Say Thank You to InfinityHelp For This Useful Post:
Old 09-16-2020, 13:31   #2 (permalink)
Member: 2941238
Exclamation Sp2 and mt2 are not open
i 2 dongle of CM2, all at sametime stop working on
MT2 and SP2, it's just blink and disappear, is it mean that my dongle as problem?, what should i do?,
i did full scan, delute folder on c"\infinity and re-install again, but still no avail,
if dongle activation expired what message used to show,
how user of infinity dongle CM2 knows that we need to re-activate?
if need to re-activate how should i do it?, to who?, or where?have.
The Following User Says Thank You to PLUSTECHPHONE For This Useful Post:
Old 09-16-2020, 13:35   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
When you need to renew support you will see a MESSAGE that dongle should be updated.
How to check support period expiration date - https://www.infinity-box.com/doc/?r=17
If support is expired please contact to your seller and renew support for 1 or 2 years - https://www.infinity-box.com/buy/
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 09-16-2020, 13:36   #4 (permalink)
Member: 130995
Do you see any message after you run software ?
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 09-29-2020, 11:04   #5 (permalink)
Member: 28536
Thanks Meter: 8
I make all.
Not work.
Old 09-29-2020, 11:18   #6 (permalink)
Member: 130995
Originally Posted by visanlg View Post
I make all.
Not work.
Try to disable "Mdm.exe Machine Debug Manager" service and reboot PC.
Result ?
Old 09-30-2020, 08:52   #7 (permalink)
Member: 28536
Thanks Meter: 8
I try on another pc and it is ok.
I must install new win7.
Thanks.
Old 09-30-2020, 23:19   #8 (permalink)
Member: 130995
Thanks.
You do not need to re-install windows.
Result ?
Old 10-01-2020, 20:21   #9 (permalink)
Member: 2955840
Thanks Meter: 83
Result ?
please, can you tell me the problem here. new cm2sp2.07 and cm2scr I need to reinstall everytime I want to make use of it. https://mega.nz/fm/ZeBz0aKQ
N.B drive C and D are in exclusion list.
THANKS IN ADVANCE.
Old 10-01-2020, 21:51   #10 (permalink)
Member: 1043909
Thanks Meter: 60,926
THANKS IN ADVANCE.
Nothing found at given link. What was there ?
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 10-01-2020, 22:22   #11 (permalink)
Member: 689942
Thanks Meter: 312
Plase helpme
my log is
Old 10-01-2020, 22:26   #12 (permalink)
Member: 689942
Thanks Meter: 312
My log is.
Please help me
Old 10-01-2020, 23:04   #13 (permalink)
Member: 2955840
Thanks Meter: 83
they are my running background application saved by sysinternals app.
https://mega.nz/file/0SggSQRQ#Zc8qce...hCALTpWCEbD9Nk
thanks
The Following User Says Thank You to Chijohn For This Useful Post:
Old 10-01-2020, 23:52   #14 (permalink)
Member: 2955840
Thanks Meter: 83
YellowBoss
https://edited
thanks
here is the correct link. https://mega.nz/file/hDJ11SrQ#Y7oItt...uV1eBOFDyi9oaY
thanks
Old 10-02-2020, 10:54   #15 (permalink)
Member: 1043909
YellowBoss
thanks
I don't see anything wrong with running processes.
Do you have fault.bin file in folder with software ?
If yes - post link here
Also use free antivirus to cure your PC:
Dr. Web CureIT https://free.drweb.com/download+cureit+free/?lng=en
Do you see any alerts by antivirus ?
Page generated in 0.27449 seconds with 10 queries
