01-31-2021, 20:50 | #1 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2054453 Status: Offline Thanks Meter: 3 | pls help me === DongleManager [Infinity] v1.80 [1/31/2021 21:45:19] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00005638200A4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 04995638 Firmware version: 0147.02 === Process started: 1/31/2021 21:45:20 === Connecting to server... Server connection successfully established Checking upgrade client version... Your upgrade client is up-to-date Checking Box/Dongle Identification... Authenticating on server... Authentication stage error: Server reported error: [0031] Not translated! |
The Following User Says Thank You to ahmedsalem0552 For This Useful Post: |
02-01-2021, 00:00 | #3 (permalink) | |
1. Read NOTE - https://www.infinity-box.com/support/?s=2 2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software ! 3. Update dongle with Infinity DongleManager.exe 4. Delete fault.bin file (if you have it in CM2 folder) 5. Run Infinity exe | |
04-05-2021, 18:12 | #5 (permalink) |
Junior Member Join Date: Mar 2021 Location: القا&# Age: 46
Member: 2983533 Status: Offline Thanks Meter: 0 | i have problem please solve DongleManager [Infinity] v1.81 [05/04/2021 18:55:35] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000004B018434082 Box/Dongle found: Infinity-Box/Dongle [CM2] Serial No (S/N): 4BBD04B0 Firmware version: 0147.02 Box/Dongle misconfiguration Diagnostic code: 66 "UK Edition" status: Off Last launched Application: 0030 v.0147 => Activations: - 00: Infinity-Box/Dongle [CM2] v0147 - 07: #7 - 0F: #15 => Options: - Infinity-Box/Dongle [CM2] - Infinity SM - amt |
04-05-2021, 18:30 | #6 (permalink) | |
1. Read NOTE - https://www.infinity-box.com/support/?s=2 2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software. 3. Update dongle with Infinity DongleManager.exe 4. Delete fault.bin file (if you have it in CM2 folder) 5. Run Infinity exe | |
