Old 06-03-2019, 18:55   #1 (permalink)
Member: 2797313
Thanks Meter: 33
Thumbs down Solution for Error [FL] : Pre-Erase ERR : 0xC0010002 Error : Flashing failed!
1- i readed full flash from phone before reset frp
2 - after reset frp phone stock on logo
3 - after flash phone from readed flash get error :
[FL] : Pre-Erase
Erase : 0x0000000000000000 : 0x0000000001088000
ERR : 0xC0010002
ERR : ABORT
ERR : 0x00000000|0x00000000
Seems as something wrong with device! Check battery charge and device state!
cause is : from flash readed from phone
slove proplem : download factory firmware and flash it
Old 06-04-2019, 02:44   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Post complete logs for determine problem.
Old 06-04-2019, 09:08   #3 (permalink)
Member: 1155715
Sonork: ahmad.derakhshan61
Thanks Meter: 23
Old 06-04-2019, 13:13   #4 (permalink)
Member: 2797313
Thanks Meter: 33
Operation : Write Flash [ v2.03 ]
Repartition : Enabled
Flash Verify : Enabled
Reg.Pre-Erase : Enabled
Verify HW/SW : Enabled
SData Backup : Disabled
Safe UserData : Disabled
Files :2
[FL] : Set : preloader_oppo6750_15131.bin
[FL] : Set : system.img
[FL] : Total size : 0xB0DE1700 [ 2.76 GB ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM58)
MODE : BOOTROM
PORT : 58
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000001
BROM : SecMode : SBC
BROM : BOOTROM
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6755
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : MT6755
EMI : SRC : preloader_oppo6750_15131.bin
EMI : CNT : 0009
EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100524531424D42 : VEN : SAMSUNG | DEV : RE1BMB : RAM : [ 3.00 GB ]
EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3.00 GB ]
EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525831424D42 : VEN : SAMSUNG | DEV : RX1BMB : RAM : [ 3.00 GB ]
EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 13014E51334A393756 : VEN : MICRON | DEV : Q3J97V : RAM : [ 3.00 GB ]
EMI : [04] : eMCP : eMMC+LP/DDR3 , ID : 150100525831344D42 : VEN : SAMSUNG | DEV : RX14MB : RAM : [ 4.00 GB ]
EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 13014E51334A393757 : VEN : MICRON | DEV : Q3J97W : RAM : [ 4.00 GB ]
EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100524331344D42 : VEN : SAMSUNG | DEV : RC14MB : RAM : [ 4.00 GB ]
EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ]
EMI : [08] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ]
EMI : Init EMI from PRELOADER
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 13014E51334A3937561003352EFCB3AD
EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q3J97V
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x747C00000 [ 29.12 GB ]
CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : E98F49A32EC954DE7ACABF50862D159D
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : MediaTek DA USB VCOM (Android) (COM57)
MODE : PRELOADER PORT
PORT : 57
Boot done!
[FL] : HW verification passed!
SEC_DL : False (RAPHAEL)
OK
SEC_ID : 0x494E46494E495459424F584245535432
[FL] : Pre-Erase
ERR : 0xC0010002
ERR : ABORT
Seems as some of MANDATORY section of FW is damaged! If device alive and work - send report!
Reconnect Power/Cable!
proplem sloved
Page generated in 0.14954 seconds with 8 queries
