05-17-2017, 14:41 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | [How To] Oppo F1s (e.g 64gb 4gb ram variant) - CM2MTK This is Oppo F1s (A1601) 64gb rom 4gb Ram Pattern locked. Operation : Check / Read Info [ v1.58 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:23 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 411 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from ScatFW! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM46H [eMMC] : FLASH_CID : 150100524836344D4202D591CE6A1439 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0xB634BF4A6F3C83245676A5C9533F1024 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : OPPO ProdName : A1601 ProdModel : A1601 Device : A1601 AndroidVer: 5.1 MTKxCPU : MT6755 MTKxPRJ : A1601EX_11_A.27_170111 SECURITY : IMEI_SW [1] : 86111703398XXXX IMEI_SW [2] : 86111703398XXXX BTMAC Addr : 4C1A3D7622B0 WiFi MAC : 4C1A3D7622B0 EXTRA : LCD : Not info available :( LCD Res : M_HEIGHT=1280xM_WIDTH=720 TOUCH [0] : STOM_KERNEL_TOUCHPANEL=GT1XX CAM [0] : STOM_HAL_IMGSENSOR=s5k3l8_mipi_raw CAM [1] : imx258_mipi_raw CAM [2] : ov8865_mipi_raw CAM [3] : s5k3p3sp_mipi_raw MODEM : oppo6750_15331_lwg Done! Elapsed: 00:00:15 Reconnect Power/Cable! Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 411 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from ScatFW! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM46H [eMMC] : FLASH_CID : 150100524836344D4202D591CE6A1439 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0xB634BF4A6F3C83245676A5C9533F1024 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! USBDL : Init HSUSB Ok Reading data ... Get Locks ... PatternLock Sequnce : 3596 Done! Elapsed: 00:00:17 Reconnect Power/Cable! https://forum.gsmhosting.com/vbb/****************************/?cxk9cu4c6fu7c3s [ size: 92 KB ] NOTE: you should ignore all the errors or values in log and concentrate only on come out. Last edited by Nasir Mobiles; 05-17-2017 at 14:47. |
The Following 51 Users Say Thank You to Nasir Mobiles For This Useful Post: |
05-18-2017, 07:15 | #3 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | PS: someone asked me phone start charging and unable to connect desire mode. for those press volume UP and insert usb cable. |
The Following 5 Users Say Thank You to Nasir Mobiles For This Useful Post: |
05-24-2017, 17:04 | #5 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | when i select this file this show- Unsupported Yet( or bad??? ) file selected! so post is not reliable. |
The Following User Says Thank You to galaxycompue For This Useful Post: |
05-25-2017, 07:52 | #8 (permalink) |
Member: 2298369 Status: Offline Thanks Meter: 440 | i think there are two different cm2 boxes/dongle available in market, in my box when i select file(which given by file) it show -Unsupported Yet( or bad??? ) file selected! but when nasir mobile select it show invalid scatter file. either two setup of cm2 exist or i have fault in my computer. set oppo a1601 is yet in my hand, can nasir mobile take team viewer to solve my problem ? |
The Following 6 Users Say Thank You to galaxycompue For This Useful Post: |
05-25-2017, 10:30 | #9 (permalink) | ||
Member: 355782 Status: Offline Thanks Meter: 1,265 | Quote:
you can contact me at skype.I'll try to help you. | ||
05-25-2017, 16:14 | #10 (permalink) |
Member: 2298369 Status: Offline Thanks Meter: 440 | today is holiday, tomorrow i'll post screenshot that file when select it show- Unsupported Yet( or bad??? ) file selected! first when it show invalid scatter file then i'll do next step, so first step is incomplete what u given in ur post, why u not try to understand this ? i don't know. |
05-25-2017, 16:53 | #11 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
this error come when u select whole firmware,,, just download scatter from post one and put the scatter on desktop and select scatter then post result | |
05-28-2017, 20:30 | #15 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | thanks bro. you have done a great job as usual. alot of this phone was retrun to customers becuse of no support by any tool. and you finnaly found a way to break oppo A S S |
The Following User Says Thank You to khanzada606 For This Useful Post: |
