12-23-2015, 12:47 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: BANGLADESH Age: 43
Member: 1306751 Status: Offline Sonork: 100.1604993 Thanks Meter: 4,916 | how to packed any spd firmware those read by infinity cm2 how to packed any spd firmware those read by infinity cm2 i can read spd firmware successfully but that don't show pac format.... so how can i convert those file into pac format |
12-23-2015, 12:58 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. You can write this FW by SPD module in any phone after. Press "PAC" button, in FileFilter select "Infinity FW *pac.sc" , select SC77xx_FLASH_CONF.pac.sc and flash phone. I not plan make Factory PAC yet, because much copypasters moving around nowdays. When they make something - will be PAC reading as well. |
02-05-2016, 14:08 | #6 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | I 100% Agreed with Jaydi sir no need to make PAC if we read with CM2 then it must be write by CM2 also that will be benifit for developers which is neccesary. |
02-05-2016, 14:15 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I changed filter in 1.14, now it by default shows all supported formats to avoid misunderstanding. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
08-02-2016, 14:24 | #8 (permalink) |
Freak Poster Join Date: May 2012 Location: Nigeria
Member: 1765167 Status: Offline Thanks Meter: 71 | I am not very comfortable with the idea of only being able to write SPD firmware read by CM2 only with CM2. We should be able to convert the files to a single .PAC format at least. I have a platform where I support people with .PAC files which they can easily flash using RD, I can't upload files that can only be flashed with CM2 because many of the people I reach out to are not technicians. JayDi please you don't have to punish your loyal costomers because of copy-pasters. Please, consider the option of reading a single .PAC firmware with CM2 or at least show us how to convert those numerous files to a single .PAC file. |
08-02-2016, 16:00 | #9 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Faisalabad Pakistan
Member: 696491 Status: Offline Thanks Meter: 164 | Agreed with @ Noble4gud Please consider this option. It will be a slap on the face of copy paster by your generousness. |
The Following User Says Thank You to netvision123 For This Useful Post: |
