Old 05-06-2009, 08:27   #1 (permalink)
rajmobile123's Avatar
Member: 578632
Thanks Meter: 229
Microsoft .NET Framework 3.5
Infinity letest realsed cdma workshop shop require Net Framework software but where we can download what is use of this software i got some information abt that i m sharing with u here!!!!
I hope it will surely help u
Brief Description
Microsoft .NET Framework 3.5 contains many new features building incrementally upon .NET Framework 2.0 and 3.0, and includes .NET Framework 2.0 service pack 1 and .NET Framework 3.0 service pack 1.
Overview
.NET Framework 3.5 builds incrementally on the new features added in .NET Framework 3.0. For example, feature sets in Windows Workflow Foundation (WF), Windows Communication Foundation (WCF), Windows Presentation Foundation (WPF) and Windows CardSpace. In addition, .NET Framework 3.5 contains a number of new features in several technology areas which have been added as new assemblies to avoid breaking changes. They include the following:
* Deep integration of Language Integrated Query (LINQ) and data awareness. This new feature will let you write code written in LINQ-enabled languages to filter, enumerate, and create projections of several types of SQL data, collections, XML, and DataSets by using the same syntax.
* ASP.NET AJAX lets you create more efficient, more interactive, and highly-personalized Web experiences that work across all the most popular browsers.
* New Web protocol support for building WCF services including AJAX, JSON, REST, POX, RSS, ATOM, and several new WS-* standards.
* Full tooling support in Visual Studio 2008 for WF, WCF, and WPF, including the new workflow-enabled services technology.
* New classes in .NET Framework 3.5 base class library (BCL) that address many common customer requests.
IMPORTANT:
* If you have installed earlier pre-release versions of .NET Framework 3.5, then you must uninstall them prior to running this installation by using Add or Remove Programs.
Download Link:
Microsoft .NET Framework 3.5 (197 mb)
http://download.microsoft.com/download/6/0/f/60fc5854-3cb8-4892-b6db-bd4f42510f28/dotnetfx35.exe
Before installing .NET Framework 3.5, you need to install Windows Inataller 3.1 Redistributable (v2), here's the download link:
http://download.microsoft.com/download/1/4/7/147ded26-931c-4daf-9095-ec7baf996f46/WindowsInstaller-KB893803-v2-x86.exe
MAKING SILENT INSTALLER:
1. Download dotnetfx35.exe and WindowsInstaller-KB893803-v2-x86.exe (links above)
2. Make the batch file with following lines:
Install.bat
@echo off
title Microsoft .NET Framework 3.5
echo.
echo Installing Windows Installer 3.1...
start /wait WindowsInstaller-KB893803-v2-x86.exe /passive /norestart
echo.
echo Installing Microsoft .NET Framework 3.5...
start /wait dotnetfx35.exe /q:a /c:"setup.exe /q /norestart" /norestart
3. Repack using winRAR, make it to extract to the temp folder and to run install.bat after extraction.
4. Installation will take up some time, to verify n check the successful install... go to the Add / Remove Programs in Control Panel, it will list the following files...
.NET Framework 2.0 Service Pack 1 (187 mb)
.NET Framework 3.0 Service Pack 1 (246 mb)
.NET Framework 3.5 (25.3 mb)
Note:
In case you need to install the .NET Framework 1.1, make it sure to install it first and then reboot before installing .NET Framework 3.5
Download Link:
Microsoft .NET Framework 1.1 (23.1 mb)
http://download.microsoft.com/download/a/a/c/aac39226-8825-44ce-90e3-bf8203e74006/dotnetfx.exe
MAKING SILENT INSTALLER: (for .net framework 1.1)
1. Download dotnetfx.exe
Install.bat
@echo off
title Microsoft .NET Framework 1.1
echo.
echo Installing Microsoft .NET Framework 1.1...
start /wait dotnetfx.exe /q:a /c:"install /l /q"
echo.
cmdow @ /HID
shutdown.exe -r -f -t 30 -c "Windows XP will restart in 30 seconds..."
EXIT
With Regard
RAJ MOBILE SALES & SERVICES
Paint.NET 3.5.3(photo manipulator) shy100 Off Topic Zone 0 02-09-2010 18:13
Microsoft .NET Framework 3.5 TUR@N ALAM Off Topic Zone 8 12-21-2008 15:45
pls help for .NET FRAMEWORK rkinfo_imran iPhone 2 / iPhone 3G / iPhone 3GS 3 10-01-2008 11:31
New Installer for Update+unlock utility. No .net Framework is required anymore .:Spitfire:. Ultimate-Sam 8 07-01-2008 12:30
Page generated in 0.12467 seconds with 9 queries
