01-31-2016, 12:28 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 477510 Status: Offline Thanks Meter: 40 | how to Qmobile Bolt T480 Hard Reset plz all bro.......... Qmobile T480 no boot InfinityBox CM2SPD MerapiTool -and Miracle_Box Truly for China Mobile plz halp me all forum |
01-31-2016, 12:33 | #2 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
CM2 work with this phone without problems. Select SC77xx mode ( last line ) Open Flash Tab , select PAC button. Choose "FileType" to Infinity SLDR , select SC773x_eMMC_v2.sldr from /CM2SPD/Models/ folder. Do need operation now. | |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
02-01-2016, 06:53 | #3 (permalink) |
No Life Poster Join Date: Feb 2010 Location: pakistan(Timergara) Age: 37
Member: 1224733 Status: Offline Thanks Meter: 158 | read pattern succesfully,all boxes failed only infinity do this here is log Card found: S/N : XXXXXXXX , v0129 Chinese Miracle II [SPD module] v 1.13 SLDR Load Ok BB CPU : SC7731 SC773x eMMc Loader v2.0 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Operation : Read PatternLock [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! FlashMode Set : Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 4587 Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to .:Zulfiqar:. For This Useful Post: |
02-01-2016, 07:15 | #4 (permalink) |
Member: 1224733 Status: Offline Thanks Meter: 158 | read flash done Card found: S/N : D3DF7963 , v0129 Chinese Miracle II [SPD module] v 1.13 SLDR Load Ok BB CPU : SC7731 SC773x eMMc Loader v2.0 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Operation : Read FullFlash [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Operation : Read FullFlash [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : QMobile_T480 Model Brand : QMobile Model Device: scx35_sp7731gea AndrVersion : 4.4.2 BaseBand CPU: SP7731GEA Project Ver : QMobile_T480_MP_31_08 Model Ext : T480 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc7731g_modem_CP2_WCN_14E_W15.16_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x800.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img Firmware Size : 1099 MiB Saved to : C:\Users\Zulfiqar\Desktop\SP7731GEA_scx35_sp7731ge a_4.4.2_QMobile_T480_MP_31_08\ Done! Elapsed: 00:12:42 Reconnect Power/Cable! |
02-25-2016, 11:27 | #5 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Hazara Mansehra
Member: 2522841 Status: Offline Thanks Meter: 61 | qmobile t480 hard reset volume down menu and power power on mobile only pressing volume down and menu |
The Following User Says Thank You to Khizar-Hayat For This Useful Post: |
03-02-2016, 14:55 | #6 (permalink) |
Freak Poster Join Date: Jan 2009 Location: PAK
Member: 954084 Status: Offline Sonork: 100.1672172 Thanks Meter: 26 | Operation : Read PatternLock [ v1.15 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Operation : Read PatternLock [ v1.15 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! FlashMode Set : Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 3578 Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to shah khalid For This Useful Post: |
03-28-2016, 11:38 | #7 (permalink) |
Member: 2522841 Status: Offline Thanks Meter: 61 | qmobile T480 hard reset volume down menu and power power on mobile only pressing volume down and menu left said menu key not pressing home key enjoying all gsm members |
03-28-2016, 17:14 | #10 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | My Re-seller Recommend me CM2 According To His 9 Years Experience And It Never Disappointed Me Even Once Since I Using . I got Miracle Box /Volcano BOx /Merapi For MTK All tools Are Good But CM2 is best Indeed. |
12-27-2018, 15:55 | #12 (permalink) |
Freak Poster Join Date: May 2007 Location: islamabad
Member: 509880 Status: Offline Thanks Meter: 16 | Infor: SPRD3 Initialize boot22... Try change bate to 230400,test again. Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Please Hold BootKey(UP and DOWN),Insert USB cable 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Scanning USB Serial port... SU2Serial Port: COM6 Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot23... Being analyzed DATA... id:QMobile_T480_MP_31_08 version:4.4.2 model:T480 brand:QMobile manufacturer:QMobile hardware:SP7731GEA_V1.0.0 Done. Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Please Hold BootKey(UP and DOWN),Insert USB cable 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Scanning USB Serial port... SU2Serial Port: COM6 Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot23... Definition Applied Scanning USB Serial port... Abort by User None SU2Serial Port. Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Please Hold BootKey(UP and DOWN),Insert USB cable 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Scanning USB Serial port... SU2Serial Port: COM6 Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot23... Formating... |
12-27-2018, 16:36 | #14 (permalink) | |
Freak Poster Join Date: Sep 2011 Location: Joined Infinity(dec2018)
Member: 1647864 Status: Offline Thanks Meter: 80 | Quote:
Go https://www.infinity-box.com/news.php, you will find the best answer for your question and confusion. Thanks | |
