08-09-2010, 11:24 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Age: 40
Member: 752606 Status: Offline Sonork: 100.1587361 Thanks Meter: 110 | voda 543 unlock done with infinity box module v3.52 Device: Vodafone-543 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7F03:A007 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [protected] type, 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C45E9 4B2.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_35C4274A].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: C45E94B2 rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 4A27C435 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 264 provider: 543X-2AVDGB1 customization: CN26FC01 customization: XN26FC01 TCL-ID identification done rom info structure: 2nd [protected] type, 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003194192 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-543_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_4 0_SP1_V32_F3__system_log_C45E94B2_35C4274A_2010080 9-152155.B0X.bin Finished, time used: 6 min 48 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! USMAN COMMUNICATIONS +92-344-8833188 [email protected] |
The Following 3 Users Say Thank You to adreesas For This Useful Post: |
08-11-2010, 19:05 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: RJ45 connector pinout: Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum |
09-10-2010, 15:59 | #6 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 605126 Status: Offline Sonork: 100.1617907 Thanks Meter: 297 | successfully unlock tooo thx infinity COM4 [VCP0] selected module v3.58 Device: Vodafone-543 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:1003:A009 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.FC15E 4E4.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_35C4274A].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: FC15E4E4 rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 4A27C435 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 264 provider: 543X-2AVDGB1 customization: CN26FC00 customization: XN26FC00 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC00 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC00 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003054308 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-543_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_4 0_SP1_V32_F3__system_log_FC15E4E4_35C4274A_2010091 0-145752.B0X.bin Finished, time used: 4 min 7 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to louisgsm For This Useful Post: |
09-21-2010, 11:22 | #7 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | COM1 [VCP4] selected module v3.48 Device: Vodafone-543 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:6103:A001 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.51E3B E89.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_35C4274A].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 51E3BE89 rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 4A27C435 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 264 provider: 543X-2AVDGB1 customization: CN26FC00 customization: XN26FC00 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC00 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC00 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003045420 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-543_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_4 0_SP1_V32_F3__system_log_51E3BE89_35C4274A_2010092 1-131806.B0X.bin Finished, time used: 5 min 59 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to MGT SOFTWARE For This Useful Post: |
02-15-2011, 10:28 | #8 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Buy Buy Thank U GsmHostig .... Age: 41
Member: 462292 Status: Offline Thanks Meter: 397 | here is another one COM182 [Serial2] selected module v3.75 Device: Vodafone-543 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001703:A009 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.76F6F 063.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_814E5441].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 76F6F063 rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 41544E81 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 267 provider: 543X-2AVDGB1 customization: CN26FC01 customization: XN26FC01 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003712011 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-543_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_4 0_SP1_V32_F3__system_log_76F6F063_814E5441_2011021 5-144957.B0X.bin Finished, time used: 5 min 20 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to kalpeshoza For This Useful Post: |
03-07-2011, 15:24 | #9 (permalink) |
Banned Join Date: Jun 2009 Location: india gujrat navsari Age: 37
Member: 1062869 Status: Offline Thanks Meter: 81 | unlock done COM22 [VCP0] selected module v3.73 Device: Vodafone-543 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:6103:A00A status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.61BED E33.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_814E5441].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 61BEDE33 rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 41544E81 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 267 provider: 543X-2EVDGB1 customization: CN26FC01 customization: XN26FC01 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003606047 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-543_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_4 0_SP1_V32_F3__system_log_61BEDE33_814E5441_2011030 7-195401.B0X.bin Finished, time used: 5 min 49 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to malektalha For This Useful Post: |
03-12-2011, 10:13 | #10 (permalink) |
Freak Poster Join Date: Dec 2007 Location: nowshera pakistan
Member: 651119 Status: Offline Sonork: 100.1603096 Thanks Meter: 48 | COM4 [VCP0] selected module v3.75 Device: Alcatel-543X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:2D03:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.1E142 1C7.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_814E5441].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 1E1421C7 rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 41544E81 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 267 provider: 543X-2FVDGB1 customization: CN26FC01 customization: XN26FC01 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003092913 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-543X_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_ 40_SP1_V32_F3__system_log_1E1421C7_814E5441_201103 12-113440.B0X.bin Finished, time used: 4 min 16 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to pine mobiles For This Useful Post: |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
