06-20-2018, 20:49 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: boghé-mauritania Age: 48
Member: 106412 Status: Offline Thanks Meter: 15 | Dslide714_v2 frp TRYing remove frp all ok but still ask frp Operation : Identify [ v2.01 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Protected! [ LOADER PROTECTED ] Machine : RK312X Device : RK3126C ExtInfo : 7.0.0 SoC CPU : 312A Flash CSx : 0x00 Flash Type : 2C646456A5 [ NAND ] Flash Vend : MICRON Flash Size : 0x000000020D000000 ( 8,20 GiB ) Flash Info : 6291456/12288/32/60/1 Connect Ok! Brand : Danew ProdName : Dslide714_v2 ProdModel : Dslide714_v2 Device : Dslide714_v2 AndroidVer: 7.1.2 Manufact. : Danew SysPatch : NHG47K RKTxCPU : RK3126C RKTxPRJ : Danew_714_v2_20170821_20170922-1939 Done! Elapsed: 00:00:08 Operation : Reset Settings [ v2.01 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Device connection test not passed! Breaking! Probably you boot device in wrong mode! Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Operation : Reset Settings [ v2.01 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Protected! [ LOADER PROTECTED ] Machine : RK312X Device : RK3126C ExtInfo : 7.0.0 SoC CPU : 312A Flash CSx : 0x00 Flash Type : 2C646456A5 [ NAND ] Flash Vend : MICRON Flash Size : 0x000000020D000000 ( 8,20 GiB ) Flash Info : 6291456/12288/32/60/1 Connect Ok! Remove FRP 0 ... FRP removed! Wiping UserData ... Wipe DATA Ok! Done! Elapsed: 00:00:12 |
