03-12-2018, 15:51 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Tabligbo
Member: 1032123 Status: Offline Sonork: akeal81 Thanks Meter: 29 | How to repair imei null on spd android I GET ITEL 1516 PLUS WITH IMEI NULL THUS NETWORK NOT COME I TRY TO REPAIR IMEI BUT PUT" WAIT PHONE SVC " and cant connect i tick "write in flash mode " but it failed how can i proceed to connect please help very urgent thanks for advance |
03-12-2018, 16:25 | #4 (permalink) |
Member: 1032123 Status: Offline Sonork: akeal81 Thanks Meter: 29 | when i try fash get error log Start at : [12/03/2018 / 15:23:11] Operation : Flash [ v1.24 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x1A records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Update NVM image : nvitem_w.bin [FlashProc] : Error with code 0x038A Elapsed: 00:00:08 Reconnect Power/Cable! Finish at : [12/03/2018 / 15:23:47] |
03-12-2018, 17:42 | #6 (permalink) |
Member: 1032123 Status: Offline Sonork: akeal81 Thanks Meter: 29 | when i done it Start at : [12/03/2018 / 16:26:38] Operation : FlashIC ReadOnly/BadBlock Test [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Prepare test data ... Test flow #0 ... Test flow passed! Test flow #1 ... Test flow passed! Test flow #2 ... Test flow passed! Test flow #3 ... Test flow passed! Test flow #4 ... Test flow passed! Test flow #5 ... Test flow passed! Finalize Ok! Test passed successfully! Elapsed: 00:00:37 Reconnect Power/Cable! Finish at : [12/03/2018 / 16:27:15] |
03-12-2018, 17:55 | #7 (permalink) |
Member: 1032123 Status: Offline Sonork: akeal81 Thanks Meter: 29 | i try erase and flash with nv update tick and still the same error "Update NVM image : nvitem_w.bin [FlashProc] : Error with code 0x038A" |
