04-13-2016, 09:39 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: in Heart of someone
Member: 1640158 Status: Offline Sonork: 100.1615555 Thanks Meter: 138 | lenovo s650 imei not writing always conming this problem all mobiles Chinese Miracle II [MTK module] v 1.45 Operation : Repair Security [ v1.45 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 50 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 1501004B375530304D0815DCC2ED6109 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00U7 [eMMC] : FLASH_CID : 1501004B375530304D0815DCC2ED6109 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : E2DD3C55975CCA07968BBDD181F0DD4E INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Set IMEI [00] : 356789765436678 Set IMEI [01] : 356789700036674 Prepare finished. Security check required! Wait for phone... Phone found! [ 50 ] Sync... Device boot not done Check Drivers Try again Error while post-checking procedure! Check drivers and battery charge! In some cases - need reconnect mobile (just re-insert cable) on this step Reconnect Power/Cable! |
