12-12-2017, 15:15 | #1 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1143383 Status: Offline Thanks Meter: 53 | How to select and use a specific DA A big problem disturbs me. Your Infinity CM2 MTK application defaults to the DA (Download Agent): mtk_allinone_da_vXXX.bin. But in many cases, this DA does not work and it is necessary to use another DA (as for example the file DA_SWSEC_1640_V2610AN_TRUNK_01.bin for some smartphones WIKO. How to select and use a specific DA with your application? Pray the steps in detail. Thank you. |
12-12-2017, 15:27 | #2 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
12-12-2017, 15:36 | #3 (permalink) |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | Hey, just pick up your DA agent, rename it with the default DA agent of infinity, then copy it to the same directory, don't forget to save the original CM2 DA first. Good luck |
12-13-2017, 10:49 | #4 (permalink) |
Member: 1143383 Status: Offline Thanks Meter: 53 | Thank you gentlemen for your quick answers. Without renaming anything, I want to put the appropriate DA in the C: \ InfinityBox \ CM2MTK \ Boot folder, then simply select this file as in SP Flash Tool. Why make it complicated when it can be simple ? |
The Following User Says Thank You to nickel2k7 For This Useful Post: |
02-01-2018, 07:28 | #6 (permalink) |
Freak Poster Join Date: Nov 2014 Location: Algeria
Member: 2287326 Status: Offline Thanks Meter: 54 | Secure boot is a nightmare on cm2, hope there will be an update soon for MTK smartphones. |
The Following User Says Thank You to Zaki Bouzidson For This Useful Post: |
