Old 08-05-2015, 15:59   #1 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Post successful Direct Phone Book extraction of MTK CPU
Card found: S/N 3F33:0000
Chinese Miracle II [MTK module] v 1.25
Operation : Read UserData [ v1.25 ]
PhoneBook : Enabled
Wait for phone...
Phone found! [ 13 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6592_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 15010051385853414206D287CC36B1F7
DA Stat : v4.2 on BBID : 0x8A
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : BASX8
[eMMC] : FLASH_CID : 15010051385853414206D287CC36B1F7
[eMMC] : FLASH_LEN : 0x00000003A3E00000
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Step #1
Step #2
Read Ok, PhoneBook records extracted : 2508
TXT Saved to : C:\Documents and Settings\Administrator\Desktop\MT6592_PhoneBook.tx t
Write : 2508
CSV Saved to : C:\Documents and Settings\Administrator\Desktop\MT6592_PhoneBook.cs v
Write : 2508
Done!
Elapsed: 00:00:30
Reconnect Power/Cable!
Model Geonee S5.1 , Display broken
Old 08-05-2015, 16:01   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
MI note - Hang on logo
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 90014A483847326404050196389561BD
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d2G8
[eMMC] : FLASH_CID : 90014A483847326404050196389561BD
[eMMC] : FLASH_LEN : 0x00000001D2000000
EXT RAM : 0x80000000
SOC VERIFY : C1
Boot Ok!
Step #1
Step #2
Read Ok, PhoneBook records extracted : 1090
TXT Saved to : C:\Documents and Settings\Administrator\Desktop\MI Note\MT6592_PhoneBook.txt
Write : 1090
CSV Saved to : C:\Documents and Settings\Administrator\Desktop\MI Note\MT6592_PhoneBook.csv
Write : 1090
Done!
Elapsed: 00:00:49
Old 08-05-2015, 16:14   #3 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Micromax A117 ( Digitizer damaged )
PhoneBook : Enabled
Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6583
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6583|6589_S00
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 484A019064314734A201860457703219
DA Stat : v3.2 on BBID : 0x86
[eMMC] : FLASH_INF : d1G4
[eMMC] : FLASH_CID : 90014A4834473164048601A219327057
[eMMC] : FLASH_LEN : 0x00000000E7000000
SOC VERIFY : C1
Boot Ok!
Step #1
Step #2
TXT Saved to : C:\Documents and Settings\Administrator\Desktop\A117\MT6583_PhoneBo ok.txt
Write : 1
CSV Saved to : C:\Documents and Settings\Administrator\Desktop\A117\MT6583_PhoneBo ok.csv
Write : 1
Done!
Elapsed: 00:00:38
The Following User Says Thank You to srinibas For This Useful Post:
Old 08-05-2015, 16:18   #4 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
K Touch M301 ( Phone Lock )
PhoneBook : Enabled
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 38 ]
Sync...
Sync Ok, read regs...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : 65F1611B44B03C8E8F2CB8EE8D4A6D11
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : EF00 4000 1600 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS : 0x003FE000 , 0x00002000
Step #1
Step #2
Read Ok, PhoneBook records extracted : 251
TXT Saved to : C:\Documents and Settings\Administrator\Desktop\M301\MT6260_PhoneBo ok.txt
Write : 251
CSV Saved to : C:\Documents and Settings\Administrator\Desktop\M301\MT6260_PhoneBo ok.csv
Write : 251
Done!
Elapsed: 00:00:22
Old 08-06-2015, 03:30   #5 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Lenovo A369i
Operation : Check / Read Info [ v1.25 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 1501004E355530304D0278FF8827317D
DA Stat : v4.2 on BBID : 0x88
[eMMC] : FLASH_INF : M00U5
[eMMC] : FLASH_CID : 1501004E355530304D0278FF8827317D
[eMMC] : FLASH_LEN : 0x00000000E9000000
EXT RAM    : 0x20000000
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : Lenovo
ProdName  : A369i
ProdModel : Lenovo A369i
Device    : A369i
AndroidVer: 4.2.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.JB3.MP.V1
Done!
Elapsed: 00:00:10
PhoneBook : Enabled
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Step #1
Step #2
Read Ok, PhoneBook records extracted : 47
TXT Saved to : C:\InfinityBox\CM2MTK\PhData\MT6572_PhoneBook_lenovo.txt
Write : 47
CSV Saved to : C:\InfinityBox\CM2MTK\PhData\MT6572_PhoneBook_lenovo.csv
Write : 47
Done!
Elapsed: 00:00:26
The Following User Says Thank You to JayDi For This Useful Post:
Old 08-06-2015, 09:23   #6 (permalink)
ishant's Avatar
Member: 1763238
Thanks Meter: 370
XOLO A550s IPS Read Phonebook Done
PhoneBook : Enabled
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 1501004E35585A4D4201D5E7CC447193
[eMMC] : FLASH_INF : BMZX5
[eMMC] : FLASH_CID : 1501004E35585A4D4201D5E7CC447193
SOC VERIFY : C1
Boot Ok!
Step #1
Step #2
Read Ok, PhoneBook records extracted : 80
TXT Saved to : C:\Users\Desktop\MT6572_PhoneBook.txt
Write : 80
CSV Saved to : C:\Users\Desktop\MT6572_PhoneBook.csv
Write : 80
Done!
Elapsed: 00:00:20
The Following 2 Users Say Thank You to ishant For This Useful Post:
Page generated in 0.20467 seconds with 8 queries
