How to solve cm2 mt2 v2 not working on windows 7 32bit & other windows STEP 1 UNTICK ALL http://i63.tinypic.com/2vhzlu9.jpg STEP 2 change installation location to program file http://i63.tinypic.com/2wei3ut.jpg |
ANOTHER WAY TO SOLVE CM2 MTK V2 NOT OPEN fs_extenal.dll size must not more than 1,100kbDEAR INIFNITY TEAM PLEASE TAKE NOTE OF THIS ON SOME PC... http://i63.tinypic.com/wsmo85.jpg in some pc after install cm2 mtk v2 and open for 1st time fs_extenal.dll size will increase to 1,156kb and cm2 mtk v2 will not open again until u reinstall... http://i64.tinypic.com/27yxr9h.jpg br. Yuslam Unique Ventures |
Thanks the successful way |
Thanks ... It is working now |
Is fs_external.dll compatible with every machine or dongle or its unique If compatible may you upload and share the good file Thanks in advance |
OR install fresh windows 7 64bit |
thank you so much its working good :) *** bless you |
need new solution software ok for the 1st opening but 2nd 3rd software hang not open |
Only one exe can be opened at the same time. Please explain what is "2nd 3rd software hang not open" means ? |
new format new pc new install software ok for the 1st open after few hours cmt2 not wotking again |
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : Huawei : TIT-series | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC_HUA_2.bin AGENT : Found MT6753 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 150100513331334D420608D29D214841 DAInf: 4 : 2 : 147 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100513331334D420608D29D21B241 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : Q313MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D4A482E5DC18245A8753682D7FFADF STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : True (CUST) SEC_DL : SECURE USB DL ENABLED SEC_ID : 0x63643666323366326630373639616230 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000080000 ERR : 0x0000177C ERR : SECURITY : SF CODE FORMAT FORBIDDEN ERR : 0x00000000|0x00000000 Error : Flashing failed! Seems as some of MANDATORY section of FW is damaged! If device alive and work - send report! Reconnect Power/Cable! |
huawei gr3 L22 flashing error how to solve.. |
@bilal khan12345 Ok, good, this means you can run CM2MT2 at your PC well |
