04-26-2016, 13:40 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | how to solve this error? => [DA_ERROR] : DRAM Configure failed! Operation : Check / Read Info [ v1.46 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E4361726420203865346081D3 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
04-27-2016, 12:42 | #3 (permalink) | |
Member: 576282 Status: Offline Thanks Meter: 145 | Quote:
I do not get you by, "Rare FORESEE Ncard ic."? The phone was coming on before I do "smart av" and "full factory reset", because it was showing ads and hanging. The two action went well, and then I do "smart av" again to be sure the virus is no more in the phone, and it shows no script again and then I just do another "factory reset" and the phone could not on again with this error shown on the log, could it be that the phone was killed by "smart av" feature or because I do "full factory reset" the second time? Please help out because the owner is on my neck now! | |
