How solve this problems with my new infinity box hi infinity team infinty help & memebers I have buy infinity box (the black one with extern-smartcard ) I have met problems when use infinity as interface , I always use COM1 port1 to success connects phones , second problem connection to 2nd CPU MTK6205 (with all phones) I always have problem (MCU 6226 always good connection) even I let phone to start completly (because 6226 start first then 6205 ex: in cect t689) please help me to solve these problems I have CECT T689 which can't set 2nd CPU (6205) IMEI (2nd sim not work) HELLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL LLLLLLLLLLLLLLLLLLLPP thanks |
This is example log: (with 6205 MCU) COM14 [VCP0] selected Action: imei imei write method: mode-2 new imei: 354101000241859 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6205:8B00]... CPU: MT6205 error: initialize step#2 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 24 sec Remove/Install battery now ! |
Hello, 1. correct place for your post is: http:///vbb/forumdisplay.php?f=425 2. what is the problems (exact description required) when you use box as interface ? 3. MT6205 connection: use another method. Read here: http:///vbb/showthread.php?t=492030 4. CECT-T689 and 2nd CPU imei: Read here: http:///vbb/showthread.php?t=492030 |
hello! connect to CPU2 and use IMEI repair method-3 for sure it will fix your imei problem. just dont forget to hold power button long enough to get it work. Phone will start up, but you must still hold power buttion- only after some time pass (arround 5 sec) second MCU will boot |
Hi and thanks for quick help I have connection problems below 1. when use box as interface (but when use PC COM1 as interface work good for MTK6226 and sometimes with MTK6205) 2. when connect to 2nd cpu (6205) even press PWR ON long time 3. as you said I tray all method to change IMEI (method-1..2..3) 4. you think that problem of connection come from drivers conflict (because I use many boxes but I never got problems from them) thanks again and viva INFINITY-BOX |
hello! Sorry, hard to undrstand: do you still having problem? |
