06-23-2006, 07:19 | #2 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Czech Republic Age: 52
Member: 72981 Status: Offline Thanks Meter: 9 | COM1 selected Device: Lobster 485 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E22212200 Check Space Done Check Data... Err: not locked or unknown eeprom Check Data Fail Finished Remove/Install battery now ! Time used: 19 sec ****************************************** Flashing my Lobster 1.1 1.3 1.4 flash for support a same problem ****************************************** COM1 selected Device: Lobster 485 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E22212200 Check Space Done Check Data... Err: not locked or unknown eeprom Check Data Fail Finished Remove/Install battery now ! Time used: 19 sec |
06-23-2006, 09:10 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Repair eeprom files uploaded in support area. !!! Make backup (read flash) before any operation with eeprom !!! Also, what you see on LCD when you power-on phone ? What is exact text on phone back label ? What is this phone history ? |
06-23-2006, 10:21 | #4 (permalink) | |
Member: 72981 Status: Offline Thanks Meter: 9 | Quote:
COM1 selected Device: Lobster 485 Checking data, wait... Action: Read Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 0001:227E22212200 Flash: 0001:227E22212200 Flash: 0001:227E22022201 Failed Finished Remove/Install battery now ! Time used: 129 sec Also, what you see on LCD when you power-on phone ? Nothing... Black screen LCD What is exact text on phone back label ? Lobster Model 485 356524000641380 S/N 03082005 MADE IN KOREA CE 0700 What is this phone history ? ?????? My Work - Only Unlock This Phone... Factory Reset to service menu ... no, erase phone code to service menu ... no Last edited by CZ Unlocker; 06-23-2006 at 10:37. | |
06-23-2006, 10:27 | #5 (permalink) |
Member: 72981 Status: Offline Thanks Meter: 9 | Flashing my lobster flashs in support infinity 1.1 1.3 1.4 worked, Flashing OK 100% .. my problem to unlock no sorry my english !! My Lobster failed read data i for Thunderstorm box... Unlock in Thunderstorm...OK i phone Enter Subsidy Password... Imei failed read to thund.box E83FD.... only box read... phone is *#06# imei OK |
06-23-2006, 10:36 | #6 (permalink) |
Member: 72981 Status: Offline Thanks Meter: 9 | NEW ACTION: WRITE REPAIR EEPROM : COM1 selected Device: Lobster 485 Checking data, wait... Action: Flash write Skip: Firmware Skip: Resourse Skip: Language Pack Write: Eeprom Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E22212200 Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Write: Eeprom Flash: 0001:227E22022201 Writing Done Finished Remove/Install battery now ! Time used: 18 sec PHONE - CONTACT SERVICE PROVIDER COM1 selected Device: Lobster 485 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... (STOPED 2MIN.) Check Parameters Fail Finished Remove/Install battery now ! Time used: 32 sec ACTION 2 - WRITE REPAIR EEPROM 2 (Lobster485_eeprom02[1].4DE.bin) COM1 selected Device: Lobster 485 Checking data, wait... Action: Flash write Skip: Firmware Skip: Resourse Skip: Language Pack Write: Eeprom Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E22212200 Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Write: Eeprom Flash: 0001:227E22022201 Writing Done Finished Remove/Install battery now ! Time used: 23 sec *************************************** COM1 selected Device: Lobster 485 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Err: boot error[04] Boot Fail Finished Remove/Install battery now ! Time used: 10 sec ****************************** COM1 selected Device: Lobster 485 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E22212200 Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Flash: 0001:227E22022201 Writing Done Finished Remove/Install battery now ! Time used: 45 sec ********************************** PHONE UNLOCKED !!!!!!!!!!!!!!!! VUÁÁÁÁÁÁÁÁÁÁÁ .... VIVAT :-)))))))))))))))) VERY VERY THX INFINITY .... !!!!!! Last edited by CZ Unlocker; 06-23-2006 at 10:57. |
Lobster 485 And Lobster 575 Full Support Added ! | irfanamin2 | FuriousGold | 2 | 07-26-2008 10:24 |
25/07/08 Lobster 485 And Lobster 575 Full Support Added ! | DARIFBS | FuriousGold | 1 | 07-25-2008 16:36 |
Cant unlock Lobster 485 phones | fonetech | ThunderStorm Box | 24 | 02-07-2006 01:40 |
How To Unlock LOBSTER 485 | imran_qasim | Various | 5 | 09-20-2005 12:02 |
