04-22-2011, 14:42 | #1 (permalink) |
No Life Poster Join Date: Jan 2005
Member: 104066 Status: Offline Thanks Meter: 62 | How to Unlock Huawei G3510 Operator Moon I have two Huawei G3510, When i insert Sim card i get message Insert Moon Sim Card. I read code but cobinaison *983*8284# don't give me possibility to Enter Codes. I Use flash in support site but Phone dead ==== [22/04/2011 14:06:16] ==== COM6 [VCP0] selected module v3.82 Device: Huawei-G3501 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware Huawei-G3510_G3510PAK_PCB01_GPRS_MT6223P_S00.G3510_V100R0 01B001C19SP03S_2011-01-05_En_Urdu.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7713:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00700000/00100000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... firmware patch (general #0)... not required firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required Special operation Done ====> Write ... Area: Firmware flash: 208848FFFFFFFF:20884800000000 Write: Firmware jump to next chip: 01 flash: 208848FFFFFFFF:20884800000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: 208848FFFFFFFF:20884800000000 error: wrong erase first sector at 0x00A50000 error: format ffs failed Finalization Fail Finished, time used: 3 min 13 sec Remove/Install battery now ! Device: Huawei-G3610 ==== [22/04/2011 14:10:08] ==== COM6 [VCP0] selected module v3.82 Device: Huawei-G3610 Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7713:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00A00000/00600000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 208848FFFFFFFF:20884800000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 208848FFFFFFFF:20884800000000 error: wrong erase first sector at 0x00A00000 error: format ffs failed Finalization Fail Finished, time used: 15 sec Remove/Install battery now Here is Full Flash and Eeprom: https://rapidshare.com/files/458649740/Huawei_G3510.rar Please need help how to unlock these phones. Thanks |
04-25-2011, 12:58 | #5 (permalink) |
Member: 104066 Status: Offline Thanks Meter: 62 | I read all carefully and after doing anythink i make full backup for this MTK phone can restore it will backup if i get somethinks wrong http://forum.gsmhosting.com/vbb/f296...-done-1246014/ G3510 unlock 100% done -------------------------------------------------------------------------------- Pinout is the same as Alcatel C701. Code: COM5 [VCP0] selected module v3.82 Action: read unlock codes unlock method: read codes Model: Huawei-G3501 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B940:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: G3501CA.P70.M11.00.10 Version: CKT23C_08B_HW ==================== New firmware found (v.3.82, database date: 04.04.2011): G3501CA.P70.M11.00.10 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 80 byte(s) read imei: 35848803022093 connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 173 byte(s) read reading data... 972 byte(s) read lock[1] code: + 47625830 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 13 sec Remove/Install battery now ! http://forum.gsmhosting.com/vbb/f296...y-box-1215234/ GOOD NEWS FOR ALL PAKISTANI USERS new ufone G3510 unlock done BY INFINTY BOX -------------------------------------------------------------------------------- tested select Model: Huawei-G3610 COM87 [VCP5] selected module v3.75 Action: read unlock codes unlock method: read codes Model: Huawei-G3610 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6591:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: G3610_V100R001B001C19SP03S Version: L75_HW 80 byte(s) read imei: 35398504418692 connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 173 byte(s) read reading data... 972 byte(s) read lock[1] code: + 41246404 lock[2] code: + 56781234 lock[3] code: + 1122 lock[4] code: - 3344 lock[5] code: - 5566 lock[6] code: + 7788 lock[7] code: + 9900 if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 11 sec Remove/Install battery now ! enter first code .......... ADVANCE GSM .. http://forum.gsmhosting.com/vbb/f296...-done-1242041/ huawei g3510s unlock done -------------------------------------------------------------------------------- open phone find pinouts under screen. unlock by smartfast option after that format fs, if not format phone wont be unlocked 100% solution. Also this combinaison *983*8284# don't work it Can we unlock this phone Thanks |
04-25-2011, 14:04 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Information: for now at least 3 types of 3510 exist: 3510 (16 mb flash) 3510m (8 mb flash) <--- your phone 3510s (4 mb flash) if you read backup with wrong model selection you can get dead phone after restore incomplete backup. You can make this now: 1. To repair phone: flash it with 3510m firmware/ffs from support area. 2. try to enter the next codes one by one and see results: *#5738# *#47454# *#774636# *#123456# *#162089# *#106488# *#65322# *#510838# *#616538# *#510868# *#510858# *#129850# *#523# *#130080# *#111552# *#128616# ###865*05# ###865*08# ###865*02# ###865*07# ###865*78# *#128529*# #*888# * #7910# *8525# #8525# *#8525# 3. if it will be no luck with codes you can try to unlock this phone with "smart fast" method (select model, that you have selected for code reading) Waiting for your results. One more important thing: what is EXACT text that you see at phone LCD when you power-on phone with wrong sim ? it will be good if you can make good quality photo and send it to [email protected] |
04-26-2011, 10:09 | #7 (permalink) |
Member: 104066 Status: Offline Thanks Meter: 62 | Hello when you power-on phone with wrong sim Insert SIm Moov (original Sim card) also this phone take 2 sims cards in 1 first slot when sim inserted i have insert moov sim and phone power off; in Second slot insert moov sim and phone still power on Not at office now i travel will try and give u the result Thanks |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
