04-13-2016, 11:27 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: In Apple Device
Member: 638481 Status: Offline Sonork: 100.1601053 Thanks Meter: 749 | Samsung Clone I9082 After Flash Dead :( need ur Help i have samsung clone i9082 it have **** virus i just flash now phone is dead but i readed 1st his files now with readed Flash Files Flashing Complet no error with CM2 tool And SP Tool But phone not live again any help to recover this phone waiting for replay |
04-13-2016, 15:12 | #3 (permalink) |
Member: 638481 Status: Offline Sonork: 100.1601053 Thanks Meter: 749 | Bro Flashing Complet with CM2 And Sp Tool I write My 1st post No error So i think no need Logs Anyway hare is pls chack And Tel me what is prob 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 40 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D00039D5F8FBFF5 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 5D48A49123A539866D5F57074B5A66CD INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6575 , Project : MTK6575 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok DRAM not initialized , will try init now DRAM init passed , 0x20000000 BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Old Dedvice , skip BatteryLevel check BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000060000 Erase : 0x0000000000D80000-0x0000000081664000 Flash Pre-Erase Done, time used : 00:00:06 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_hexing75_jb.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:12:10 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:45 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:13:24 Reconnect Power/Cable! |
04-13-2016, 16:24 | #8 (permalink) |
No Life Poster Join Date: Nov 2007 Location: ☆I-LOVE Pakistan☆
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | cm2 do not dead if you flash without erase Now you send here first backup file name this like MT6575___GT-I9082__GT-I9082__4.2.2__ALPS.JB.MP.V1.16 More help full |
The Following User Says Thank You to rafi_5217705 For This Useful Post: |
04-13-2016, 16:25 | #9 (permalink) |
Member: 638481 Status: Offline Sonork: 100.1601053 Thanks Meter: 749 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 40 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D00039D5F8FBFF5 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 5D48A49123A539866D5F57074B5A66CD INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , M00SJ , 0xE9000000 , 3728 MiB [eMMC] : CID : 1501004E4A5330304D00039D5F8FBFF5 [eMMC] : MODE : SQ-WR [FAILED] : Probably, something wrong with eMMC! Check cable and battery! Operation Failed Elapsed: 00:00:40 Reconnect Power/Cable! |
04-13-2016, 16:40 | #11 (permalink) |
Member: 638481 Status: Offline Sonork: 100.1601053 Thanks Meter: 749 | Dear Bro This Is Not Solution We Comes From Home For Work & This Is Over Incom Sores So Allways Try To Do Batter & Batter ! Day U Will Be Able To Do Every Thing Hope U Understand |
04-13-2016, 16:42 | #12 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Check side keys. Or not hold them, while connect phone. If keys ok and you not press them - then it mostly mean some problem with HW - eMMC. |
04-13-2016, 17:40 | #15 (permalink) |
Junior Member Join Date: Mar 2006
Member: 245245 Status: Offline Thanks Meter: 1 | hi, pls check ur log , it says preloader not active ( erased) most important for the mobile to power on. i do have this issue , trying to figure how to set preloader to active . |
The Following User Says Thank You to dhansinghani For This Useful Post: |
