09-08-2011, 16:35 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Is possible read cpu mt6238? COM10 [Serial5] selected module v4.01 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6238:8A01:8A00]... CPU: MT6238 high speed boot On chip: 0000:0000:800B status: 02 boot packet size: 0400 error: bootcode start error: A4 not authorized: 000000A4 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... error: no any expected answer : wrong answer after chip cfi request number of flash chip/regions detected: 00/01 flash chip is unknown or damaged. Fault reasons: 1. unknown hardware: contact to support: [email protected] 2. hardware is damaged: check hardware, water inside etc. Initialize Fail Finished, time used: 28 sec Remove/Install battery now ! COM10 [Serial5] selected module v4.01 Device: _Autodetect MT6228-6268 NAND Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6238:8A01:8A00 status: 02 bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 sec error code: AA error: can not boot device: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE error: last error: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE Disconnect... done Finished, time used: 6 sec Remove/Install battery now ! COM10 [Serial5] selected module v4.01 Device: _Autodetect MT6253 NOR Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6238:8A01:8A00 status: 02 bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 sec error code: AA error: can not boot device: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE error: last error: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE Disconnect... done Finished, time used: 15 sec Remove/Install battery now ! i try in all option thanks |
09-10-2011, 09:50 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! Seems to be not supported for now. we are constantly working under adding support of new type CPUs to our software. Updates will follow... |
Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-22-2011 15:55 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
