01-02-2010, 12:28 | #1 (permalink) |
Temporary banned !! Join Date: Apr 2007
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | pana v1.73 cannot unlock huawei t156 => operation (3) started: COM6 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081039265189 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status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restore original mode... last error: No errors => operation finished ==> close_com_port => module version: v.1.73 => operation (3) started: COM6 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081033481352 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status (020A): 010001004800E0000200010028011800030001004001B80004 000E00F801000010000100F801100011000E00080200001200 0E000802000013000E000802000014000E0008020000000109 00000000000000000000000000000000000100000001010101 00000000090000000000000000000000000000000100000000 00000000000000000000000505000000000000000000000000 00000000000000000000000000000000000000000000000000 00050500000000000000000000000000000000000000000000 00000000000000000000000000000000050500000000000000 00000000000000000000000000000000000000000000000000 00000000000005050000000000000000000000000000000000 00000000000000000000000000000000000000000000012F10 010000000000207F076FFFFFFFFF0000090000000001000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000132743008310632040141003F00000000 ==> restore original mode... last error: No errors => operation finished ==> close_com_port not unlock what i do? any solution |
01-05-2010, 09:53 | #3 (permalink) |
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | HERE IS SOLUTION UNINSTAL PANA V1.73 & DELETE C>INFINITY-BOX>PANA01 FOLDER , & THAN INSTAL AGAIN UNLOCK DONE => module version: v.1.73 => operation (3) started: COM6 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081033494710 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status: 020A ==> unlock... verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 ==> restore original mode... last error: No errors => operation finished ==> close_com_port Finished, time used: 21 sec Power Off/On phone now ! UNLOCK DONE T156 |
Successfully unlock huawei t156 by infinty | SOHAIL BASHARAT | Infinity-Box | 39 | 02-03-2012 03:37 |
Unlocking huawei t156 | SAM5 | FuriousGold | 14 | 03-23-2009 14:37 |
Furious gold is not perfect to unlock huawei t156 | dawah telecom | FuriousGold | 1 | 01-16-2009 23:21 |
unlock Huawei T156 | multi_mobile | Infinity-Box | 2 | 11-21-2008 13:53 |
Any body Unlocked Huawei T156? | Tahir Riaz | Infinity-Box | 1 | 11-21-2008 13:46 |
