How to use and how to flash chaina mobiles How to use and how to flash chaina mobiles with Infinity Box i am just new & any Video Tutorials ?? |
Hello, 1. C:\Program Files\InfinityBox\Documentation\ChineseMiracle 2. How to write flash (upgrade/downgrade firmware, change language): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not wrks try to make "complete" format (if this option exist) 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
thanks for useful info. |
infinity said it all to u mate :) Need not any tips now jus read them documentations.. Br, |
thanks for useful info Inifinity Team . thanks ................ |
