Old 02-01-2021, 02:53   #46 (permalink)
Member: 2716325
Thanks Meter: 2
Originally Posted by JayDi View Post
With v2.19 we bring new way to make your life easy.
If you get new/unknown device, which you need service and it build on new platfrom ( we call it RAPHAEL ) you need have correct boot configuration.
Till now were required to select preloader or make HWreport.
Now it look another...
If you boot device and see such message from software, when do some operation :
DO NOT PANIC!!!!
That is completely okay!
Just repeat need operation ONE MORE TIME!
After self-learn software will not ask anything more for that device. You can proceed with need service actions.
It is main working case. But sometimes you may get more strange and scary message :
DO NOT PANIC!!!!
Maybe, it ask 1-2 more time. 3 is an maximum.
After repeat you should get such message :
DO NOT PANIC!!!!
That is completely okay! And mean software found, learned and ready to service your device!
After you will get result :
So, 1-3 clicks required sometimes
thanks for this tutorial work around..
Old 02-01-2021, 13:17   #47 (permalink)
Member: 2847719
thanks for good update
especially sticky guid
Old 02-03-2021, 01:32   #48 (permalink)
Member: 1791906
Thanks Meter: 2
good wook i am now on V2:21, infinity box credit to you
Old 02-03-2021, 16:47   #49 (permalink)
Member: 201238
Thanks Meter: 24
infinix x690 reset ok report
Card found : ECFF56E3 , v0147
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21
Load IDBase v21168 Ok!
Operation : HW Report [ v2.21 ]
HWreport : Mode : eMMC
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port_V1632 (COM111)
MODE : BOOTROM
PORT : 111
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Talbot
TYPE : MODERN RAPHAEL
BROM : MEID : 0E701117A22CFF59C983C04D0EDE54CE
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v2044 | Manual : Disabled
BROM : SOCID : 75BB8AD230C79089CF71150769037A85E98C2B1B54FEF6D59C D83B75AC5EAFB6
BROM : SLA : Local Auth
BROM : SLA : Auth Started!
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6768
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : PRELOADER_INFINITY_0
EMI : CNT : 0001
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00070000 [ 448.00 KB ]
DRAM: 0x100000000 [ 4.00 GB ]
EMMC: 13014E53304A394B39101DC7D1D4570F
EMMC: VEN : MICRON | OEM : 4E01 | DEV : S0J9K9
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x01000000 [ 16.00 MB ]
USER : 0x1D1F000000 [ 116.48 GB ]
CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000
RNID : C4A498922956ABFB41D9F4D36DBD57E2
DA : USB : HIGH-SPEED
Boot done!
Memory Info :
CID : 13014E53304A394B39101DC7D1D4570F
MEM : VEN : MICRON | OEM : 4E01 | DEV : S0J9K9
DAT : Size: 119280 MB, Max.Speed: 52000 kHz, blklen(512), nblks(244285440), ro(0)
EXT_CSD Info :
EXT_CSD rev. : v1.8 ( MMC v5.1 )
CSD struct rev. : v1.2
Supported command sets : 1h
HPI features : 1h
BG operations support : 1h
BG operations status : 0h
Correct prg. sectors : 0h
1st init time after part. : 3000 ms
Min. write perf.(DDR,52MH,8b): 80h
Min. read perf. (DDR,52MH,8b): 0h
TRIM timeout: 0 ms
Secure feature support: 55h
Secure erase timeout : 60000 ms
Secure trim timeout : 60000 ms
Access size : 4608 bytes
HC erase unit size : 512 kbytes
HC erase timeout : 600 ms
HC write prot grp size: 8192 kbytes
HC erase grp def. : 0h
Reliable write sect count: 1h
Sleep current (VCC) : 8h
Sleep current (VCCQ): 8h
Sleep/awake timeout : 419430400 ns
Sector count : e8f8000h
Min. WR Perf. (52MH,8b): 80h
Min. Read Perf.(52MH,8b): 0h
Min. WR Perf. (26MH,8b,52MH,4b): 4eh
Min. Read Perf.(26MH,8b,52MH,4b): 0h
Min. WR Perf. (26MH,4b): 2bh
Min. Read Perf.(26MH,4b): 0h
Power class: 0
Power class(DDR,52MH,3.6V): 0h
Power class(DDR,52MH,1.9V): 0h
Power class(26MH,3.6V) : 0h
Power class(52MH,3.6V) : 0h
Power class(26MH,1.9V) : 0h
Power class(52MH,1.9V) : 0h
Part. switch timing : 3h
Out-of-INTR busy timing: ah
Card type : 57h
Command set : 0h
Command set rev.: 0h
HS timing : 0h
Bus width : 0h
Erase memory content : 0h
Partition config : 48h
Boot partition size : 4096 kbytes
Boot information : 7h
Boot config protection: 0h
Boot bus width : 2h
Boot area write prot : 0h
User area write prot : 0h
FW configuration : 0h
RPMB size : 16384 kbytes
Write rel. setting : 1fh
Write rel. parameter: 15h
Start background ops : 0h
Enable background ops: 2h
H/W reset function : 1h
HPI management : 0h
Max. enhanced area size : 1368h (40697856 kbytes)
Part. support : 7h
Part. attribute: 0h
Part. setting : 0h
General purpose 1 size : 0h (0 kbytes)
General purpose 2 size : 0h (0 kbytes)
General purpose 3 size : 0h (0 kbytes)
General purpose 4 size : 0h (0 kbytes)
Enh. user area size : 0h (0 kbytes)
Enh. user area start: 0h
Bad block mgmt mode: 0h
Overall status :
MLC status : 0% - 10% used
SLC status : 0% - 10% used
EOL status : Normal ( Less than 80% reserved blocks used )
RPMB : RPMB KEY NOT set! [State : CLEAN : USABLE]
Done!
Elapsed: 00:00:28
Operation : Reset Settings/Format FS [ v2.21 ]
Mode : SMART RESET
MODE : BOOTROM
PORT : 111
BROM : Init BROM
BROM init passed!
CODE : Talbot
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0001
EMMC:
Boot done!
Done!
Elapsed: 00:00:32
Reconnect Power/Cable!
Mode : SMART RESET
MODE : BOOTROM
PORT : 111
BROM : Init BROM
BROM init passed!
CODE : Talbot
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0001
EMMC:
Boot done!
SmartInfo : 0x825657
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:39
The Following 3 Users Say Thank You to khurram6230 For This Useful Post:
Old 02-07-2021, 05:46   #50 (permalink)
Member: 1791906
Thanks Meter: 2
please can somebody help me with this issue, i am unable to write nvram with this. the dialogue propose this format mt_sec but i don't know exactly what to do.
File Type: jpg 20210206_215506.jpg (157 Bytes, 247 views)
Old 02-07-2021, 15:01   #51 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
NVRAM in binary format you can write over MEMORY TOOL or via enable EXTENDED option in flashing tab, then select scatter and specify NVRAM file. Also, filter of extension allow change it to BIN format also.
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Old 02-08-2021, 04:12   #52 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,053
Originally Posted by khanzada606 View Post
upload video tutorial on YouTube is the best and easiest way for noobs like me 😥
I do agree I still want more videos to learn faster.
Br,
xerraco
Old 02-08-2021, 08:30   #53 (permalink)
JayDi's Avatar
Member: 462970
Br,
xerraco
In first post screens explain all, what need.
In video will be same, but with runnin in panic mouse cursor around.
Old 02-12-2021, 05:29   #54 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 264
i am trying redmi 6a to read
what am i doing wrong or what do i need to do?
Card found : 6359E774 , v0147
PTFN : MediaTek USB Port (COM18)
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
     CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     CODE : Cervino
BROM : MEID : AE7BF21B4893134D12953E85A7E8941C
BROM : SecLevel : 0x000000E7
BROM : SecMode  : SBC+SLA+SDA+EXT
BROM : BOOTROM
BROM : SOCID : 7021FA2C6EFD8E08869129D201D35CAC8F0F57F7D3A95086E670BA79794EDE59
Error : Fail to init protocol!
>>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Info : LEGACY : HW reporting feature unavailable for current device!
Done!
Elapsed: 00:00:20
Operation : Identify [ v2.21 ]
Mode : FLASH
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
Mode : FLASH
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
MODE : Xiaomi : 6A | Manual : Disabled
Mode : FLASH
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
AGENT : Found MT6765
  BROM  : 0x00000001 : DA SEND ERROR!
  ERROR : BROM : DL MODE ERROR
  INFO : BROM Level : SLA AUTH or AUTH required!
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
Done!
Elapsed: 00:00:10
Old 02-12-2021, 22:12   #55 (permalink)
Member: 1677653
Thanks Meter: 2,769
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
Done!
Elapsed: 00:00:20
Mode : FLASH
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
Mode : FLASH
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
Mode : FLASH
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
Done!
Elapsed: 00:00:10
Try to tick sSLA.... .
Old 02-13-2021, 02:57   #56 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 264
already did, but still the same error..
Old 02-13-2021, 07:49   #57 (permalink)
JayDi's Avatar
Member: 462970
Re-install MT2.
Re-install latest drivers from support area.
Start MT2. Try connect device once.
Restart MT2.
done.
Old 03-06-2021, 23:37   #58 (permalink)
Crazy Poster
Member: 1997186
Thanks Meter: 5
Great update infinity.!
Old 05-23-2021, 19:56   #59 (permalink)
JayDi's Avatar
Member: 462970
FireFly Core activated. Not need care anymore about correct preloader for 90% of supported models.
Old type :
Operation : Identify [ v2.24 ]
Mode : FLASH
PTFN : MediaTek USB Port_V1633 (COM6)
MODE : BOOTROM
PORT : 6
BROM : Init BROM
BROM init passed!
     CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
BROM : SecLevel : 0x00000000
BROM : SecMode  : PLAIN [+PRL]
BROM : BOOTROM
MODE : 0_base : BASE_v2112 | Manual : Disabled
BROM : EMI : DevInit
BROM : EMI : DevInit Ok!
AGENT : Found MT6580
BROM : DA sent
     DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 44000145303034476BDxxxxxxxxxxxx
DAInf: 4 : 2 : 156
eMMC : OK
eMMC : 45010044473430303801xxxxxxxxxxxxxxx
DRAM : 0x0178
     EMI : DEV : FireFly
     EMI : SRC : preloader_bird_o1mp2_k80_bsp_512m.bin
     EMI : CNT : 0001
INIT : 0xBC : DRAM [ 0x00000000 :  [ 0 B ] ]
DRAM : DRAM: 0x20000000 [ 512,00 MB ]
     DA : DRAM ready!
        EMMC: 450100444734303038xxxxxxxxxxxxxx
        EMMC: VEN : SANDISK | OEM : 01 | DEV : DG4008
        EMMC:
              BOOT1  : 0x00400000 [ 4,00 MB ]
              BOOT2  : 0x00400000 [ 4,00 MB ]
              RPMB   : 0x00400000 [ 4,00 MB ]
              USER   : 0x1D21D0000 [ 7,28 GB ]
        SRAM: 0x00020000 [ 128,00 KB ]
        CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : MediaTek DA USB VCOM (Android) (COM14)
MODE : PRELOADER PORT
PORT : 14
Boot done!
Patch Level    : O11019
Display ID     : 7130D_S8020K_E.A1.20180808.AD80.V21.WVGA.DS84.B18.MP.RU
Ver. CodeName  : REL
Ver. Release   : 8.1.0
Sec. Patch     : 2018-07-05
Build Time     : 08.08.2018
Product Info   : Impress_Funk
Product Model  : Impress_Funk
Product Brand  : Vertex
Product Name   : Impress_Funk
Product Device : Impress_Funk
Product Board  : Impress_Funk
Product Manfct : Vertex
Board Platform : mt6580
USERDATA : FILESYSTEM : F2FS  with FDE ( Full Disk Encryption ***)
IMEI[0] : 35xxxxxxxxxxxxxxx
IMEI[1] : 35xxxxxxxxxxxxxxx
NVRAM check : Passed!
NVRAM : SEC NORMAL  [ No extra security ]
Backup sensetive data [ 14 ]
Backup path : Backup\MT6580__xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\
Backup done!
PRELOADER : DEVICE :
DEV : MT6752
NME : preloader_bird_o1mp2_k80_bsp_512m.bin
CNT : 0001
Done!
Elapsed: 00:00:52
Modern :
Operation : Read Firmware [ v2.24 ]
ExtSparse   : Enabled
ForceRead   : Disabled
MODE : BOOTROM
PORT : 6
BROM : Init BROM
BROM init passed!
     CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200
     CODE : Merlot
BROM : BOOTROM
BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
AGENT : Found MT6761
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : FireFly
     EMI : SRC : preloader_k61v1_32_bsp_hdp.bin
     EMI : CNT : 0003
        SRAM: 0x0003A400 [ 233,00 KB ]
        DRAM: 0x80000000 [ 2,00 GB ]
        EMMC: 150100514531334D420xxxxxxxxxxxx
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE13MB
        EMMC:
              USER   : 0x3A3E00000 [ 14,56 GB ]
        CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
Boot done!
Product Brand  : Ulefone
Product Device : Armor_X7_Q
Product Model  : Armor X7
Product Name   : Armor_X7_Q_EEA
Patch Level    : QP1A.190711.020
Display ID     : P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0114.V3.03
Ver. CodeName  : REL
Ver. Release   : 10
Sec. Patch     : 2020-12-05
Build Time     : 14.01.2021
Product Info   : Armor_X7_Q
Product Board  : Gotron-GQ3087SH2
Board Platform : mt6761
Product Manfct : Ulefone
Display ID     : P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0122.V3.03
MT6761__10__P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0122.V3.03__QP1A.190711.020__Armor_X7_Q
Read : preloader.bin
Read : proinfo.img
Read : recovery.img
Read : vbmeta_system.img
Read : vbmeta_vendor.img
Read : seccfg.img
Read : persist.img
ExtSparse : Compression ratio : 100%
Read : md1rom.img
Read : spmfw.img
Read : tinysys-scp.bin
Read : tinysys-sspm.bin
Read : nvram.bin
Read : lk.bin
Read : boot.img
Read : logo.bin
Read : dtbo.img
Read : tz.img
Read : super.img
ExtSparse : Compression ratio : 45%
Read : vbmeta.img
Read : cache.img
Read : userdata.img
FW Size  : 2,42 GB
Android Info saved : _Android_info.txt
Scatter  : MT6761_Android_scatter.txt
Saved to : C:\MTK\MT6761__10__P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0122.V3.03__QP1A.190711.020__Armor_X7_Q\
Done!
Elapsed: 00:07:28
New :
Mode : FLASH
MODE : BOOTROM
PORT : 6
BROM : Init BROM
BROM init passed!
     CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     CODE : Krug
BROM : BOOTROM
BROM : SLA : Look for cookies
AGENT : Found MT6785
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : FireFly
     EMI : SRC : preloader_begonia.bin
     EMI : CNT : 000A
        SRAM: 0x00080000 [ 512,00 KB ]
        DRAM: 0x180000000 [ 6,00 GB ]
        UFS: AD014839485131364145434D4D444152
        UFS:
             VEN  : 0x01AD
             VID  : H9HQ16AECMMDAR
             IFW  : A107
             LU0  : 0x00400000 [ 4,00 MB ]
             LU1  : 0x00400000 [ 4,00 MB ]
             LU2  : 0x1DCB000000 [ 119,17 GB ]
             FSN  : xxxxxxxxxxxx
             REG  : 0x101010000
        CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
Boot done!
Patch Level    : PPR1.180610.011
Display ID     : PPR1.180610.011
Ver. CodeName  : REL
Ver. Release   : 9
Sec. Patch     : 2019-12-01
Build Time     : 07.01.2020
Product Model  : Redmi Note 8 Pro
Product Brand  : Redmi
Product Name   : begonia
Product Device : begonia
Product Info   : begonia
Product Manfct : Xiaomi
Product Board  : begonia
Board Platform : mt6785
NVRAM check : Failed! NVRAM damaged!
NVRAM : SEC SIGNED  [ IMEI RSA SIGNED ]
Backup path : Backup\MT6785__xxxxxxxxxxxxxxxxxxxxxxxx\
Backup done!
STORAGE : LifeStatus : UFS : OK!
DEV : MT6752
NME : preloader_begonia.bin
CNT : 000A
 EMI : [00] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6,00 GB ]
 EMI : [01] : eUFS : LP_DDR4X : DEV : H9HQ53ACPMMDAR : RAM : [ 4,00 GB ]
 EMI : [02] : eUFS : LP_DDR4X : DEV : H9HQ53AECMMDAR : RAM : [ 6,00 GB ]
 EMI : [03] : eUFS : LP_DDR4X : DEV : KM5H7001DM-B424 : RAM : [ 4,00 GB ]
 EMI : [04] : eUFS : LP_DDR4X : DEV : KM2H7001CM-B518 : RAM : [ 6,00 GB ]
 EMI : [05] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6,00 GB ]
 EMI : [06] : eUFS : LP_DDR4X : DEV : MT064GASAO2U21 : RAM : [ 4,00 GB ]
 EMI : [07] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8,00 GB ]
 EMI : [08] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 6,00 GB ]
 EMI : [09] : eUFS : LP_DDR4X : DEV : H9HQ21AFAMZDAR : RAM : [ 8,00 GB ]
Done!
Elapsed: 00:00:29
The Following 7 Users Say Thank You to JayDi For This Useful Post:
Page generated in 0.38729 seconds with 9 queries
