Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #31 (permalink) | |
Insane Poster ![]() ![]() ![]() Join Date: Jun 2020 Location: Earth Age: 27
Member: 2958962 Status: Offline Thanks Meter: 27 | Quote:
![]() | #32 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2016
Member: 2607653 Status: Offline Sonork: family members Thanks Meter: 156 | sir Lava Iris88 not support. i have device in hand now Operation : Identify [ v2.20 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM118) MODE : BOOTROM PORT : 118 Error : Failed to open port! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.20 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM118) MODE : BOOTROM PORT : 118 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Zion TYPE : MODERN RAPHAEL BROM : MEID : 2F59DFA0964DDB982DF85A2C90BB6322 BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : BQ : SEC_6739 | Manual : Disabled BROM : SOCID : 266DC60FDDE6545866F071EA79EE1719AFB2C9D69BA0250B89 8974FB4033548A AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SETUP HW PARAMS FAILED! PROTO_VER is OLD? Error : Fail to init protocol! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! |
![]() | #33 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 1,927 | Quote:
https://www.youtube.com/watch?v=I1qQlm6s7I8 BR | |
![]() | #34 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2007 Location: Infinity-Box Support India-
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,194 ![]() | Quote:
Download and install latest driver from support area. Connect phone once with software, close software ,open again and do required operation. Hope will get solved. And with latest version no need any DA or PRL. Br. Infinity-Box Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
![]() | #35 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2011 Location: Armenia Yerevan
Member: 1559514 Status: Offline Thanks Meter: 49 | ![]() Operation : Identify [ v2.20 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM71) MODE : BOOTROM PORT : 71 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : 839C5CBA14539C16D4FD81470B63AB69 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 5BFFF127E0191460D6A06A17CA8E4380173848C7860AD67A9E 516C02B4C6B873 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 150100445036444142032BE6D40457CB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DP6DAB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 65D62B71F320EBFDBBF0EE1575E89456 DA : USB : HIGH-SPEED Boot done! Product Brand : Redmi Product Device : lancelot Product Model : lancelot Product Name : lancelot_global Patch Level : QP1A.190711.020 Display ID : build-20201215100645 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-11-01 Build Time : 15.12.2020 Product Info : lancelot Product Manfct : Xiaomi Product Board : lancelot Board Platform : mt6768 USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC SIGNED [ IMEI RSA SIGNED ] Backup sensetive data [ 11 ] Backup path : Backup\MT6768__65D62B71F320EBFDBBF0EE1575E89456\ [23] Read : NVRAM [13] Read : NVDATA [20] Read : PROINFO [33] Read : LK [12] Read : NVCFG [16] Read : PROTECT1 [17] Read : PROTECT2 [14] Read : PERSIST [0] Read : PRELOADER [18] Read : SECCFG Backup done! STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:01:18 trying to flashing add log later... |
The Following 4 Users Say Thank You to Varazdat For This Useful Post: |
![]() | #36 (permalink) |
Member: 1559514 Status: Offline Thanks Meter: 49 | Redmi 9 with miui 12.0.5.0 flashing lower version V11.0.5.0 done cm2mtk2 NWRAM IS LOST AFTER !!! FOR FIRST DO BACKUP!!! 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM71) MODE : BOOTROM PORT : 71 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : 839C5CBA14539C16D4FD81470B63AB69 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 5BFFF127E0191460D6A06A17CA8E4380173848C7860AD67A9E 516C02B4C6B873 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_lancelot.bin EMI : CNT : 0008 EMI : [00] : eMMC : LP_DDR4X : ID : 150100444436384D42 : VEN : SAMSUNG | DEV : DD68MB : RAM : [ 3.00 GB ] EMI : [01] : eMMC : LP_DDR4X : ID : 13014E53304A394A38 : VEN : MICRON | DEV : S0J9J8 : RAM : [ 3.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 150100445036444142 : VEN : SAMSUNG | DEV : DP6DAB : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 13014E47314A395238 : VEN : MICRON | DEV : G1J9R8 : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 90014A684445615033 : VEN : HYNIX | DEV : hDEaP3 : RAM : [ 6.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 150100335036434D42 : VEN : SAMSUNG | DEV : 3P6CMB : RAM : [ 6.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON | DEV : G1J9S9 : RAM : [ 4.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 150100445036444142032BE6D40457CB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DP6DAB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 65D62B71F320EBFDBBF0EE1575E89456 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x000000000A4A2000 Erase : 0x000000000C4A2000 : 0x0000000004000000 Erase : 0x0000000017800000 : 0x0000000000A00000 Erase : 0x0000000018500000 : 0x0000000001A00000 Erase : 0x000000001DF00000 : 0x000000030E900000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : VBMETA Write : VBMETA_SYSTEM Write : VBMETA_VENDOR Write : LOGO Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : DTBO Write : TEE1 Write : TEE2 Write : EXAID FAIL : SEC : IMG TOO LARGE Write : CUST FAIL : SEC : IMG TOO LARGE Write : SUPER Write : CACHE Write : USERDATA Ultra : Ok! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:03:23 Reconnect Power/Cable! Last edited by Varazdat; 01-29-2021 at 17:15. |
The Following 3 Users Say Thank You to Varazdat For This Useful Post: |
![]() | #38 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2007
Member: 573393 Status: Offline Thanks Meter: 11 | plz helpe: === DongleManager [Infinity] v1.81 [29/01/2021 20:54:07] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0275079918944812 === Process started: 29/01/2021 20:54:07 === Connecting to server Server connection successfully established Checking DongleManager version... Version check error: Socket Error # 10054 Connection reset by peer. |
![]() | #39 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2010 Location: 90-region Age: 36
Member: 1246378 Status: Offline Thanks Meter: 120 | Xiaomi Redmi note 9 merlin muiu 12.0.6 downgrade miui 11 flashed ok Operation : Write Flash [ v2.20 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :23 [FL] : Set : preloader_merlin.bin [FL] : Set : recovery.img [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : logo.bin [FL] : Set : md1img.img [FL] : Set : spmfw.img [FL] : Set : scp.img [FL] : Set : scp.img [FL] : Set : sspm.img [FL] : Set : sspm.img [FL] : Set : lk.img [FL] : Set : lk.img [FL] : Set : boot.img [FL] : Set : dtbo.img [FL] : Set : tee.img [FL] : Set : tee.img [FL] : Set : exaid.img [FL] : Set : cust.img [FL] : Set : super.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x16C36AF40 [ 5,69 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM94) MODE : BOOTROM PORT : 94 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : 7A0F5ACC74B3B3A0314101A4BE7B54FC BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 5E15AE61AE5607FB78ED3E0E358FD94A35C9786E53EF6A2E8F 833902DAC72BFC BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_merlin.bin EMI : CNT : 0009 EMI : [00] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3,00 GB ] EMI : [01] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6,00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100334836434142 : VEN : SAMSUNG | DEV : 3H6CAB : RAM : [ 6,00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 13014E53304A394B38 : VEN : MICRON | DEV : S0J9K8 : RAM : [ 4,00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4,00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 150100445036444142 : VEN : SAMSUNG | DEV : DP6DAB : RAM : [ 4,00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON | DEV : G1J9S9 : RAM : [ 4,00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 13014E53304A394A38 : VEN : MICRON | DEV : S0J9J8 : RAM : [ 3,00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 150100445636444142 : VEN : SAMSUNG | DEV : DV6DAB : RAM : [ 4,00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448,00 KB ] DRAM: 0x100000000 [ 4,00 GB ] EMMC: 13014E53304A394A38101F8E1FF68745 EMMC: VEN : MICRON | OEM : 4E01 | DEV : S0J9J8 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0xE8F800000 [ 58,24 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 35D426FF8BD1A185AF5175953B8CD2E1 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x000000000A4A2000 Erase : 0x000000000C4A2000 : 0x0000000004000000 Erase : 0x0000000017800000 : 0x0000000000A00000 Erase : 0x0000000018500000 : 0x0000000001A00000 Erase : 0x000000001DF00000 : 0x000000030E900000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : VBMETA Write : VBMETA_SYSTEM Write : VBMETA_VENDOR Write : LOGO Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : DTBO Write : TEE1 Write : TEE2 Write : EXAID FAIL : SEC : IMG TOO LARGE Write : CUST FAIL : SEC : IMG TOO LARGE Write : SUPER Write : CACHE Write : USERDATA Ultra : Ok! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:03:25 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to ganjbek For This Useful Post: |
![]() | #40 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2007
Member: 574410 Status: Offline Thanks Meter: 86 | reno 2f failed Operation : Identify [ v2.20 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM93) MODE : BOOTROM PORT : 93 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : 7FEE66FC1208C993D72BF02714AB1F50 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 762D23CDCF8395B8B52A88FAFC11CF88FBCBEBFE9F99BED79C 19AF8AD3780892 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Boot done! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
![]() | #41 (permalink) |
![]() | #42 (permalink) |
Member: 2665389 Status: Offline Thanks Meter: 1,927 | Clarifications: - Preloader Port protocol: The phone is completely turned off and we do not press any key that is to say neither vol + nor vol- or both at the same time and we connect with the usb cable. -Brom Port protocol: The phone is completely off and we press vol +, vol- or both keys at the same time depending on the brand and model of the phone and connect with the usb cable, in some phones we have to force boot with test point. BR |
The Following 2 Users Say Thank You to Franky_36 For This Useful Post: |
![]() | #43 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007
Member: 462970 Status: Offline Thanks Meter: 18,764 | Quote:
![]() | #45 (permalink) |
Member: 574410 Status: Offline Thanks Meter: 86 | just amazing Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.20 Load IDBase v125162 Ok! Operation : Identify [ v2.20 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM131) MODE : BOOTROM PORT : 131 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : 7FEE66FC1208C993D72BF02714AB1F50 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : F11-Reno2F | Manual : Disabled BROM : SOCID : 762D23CDCF8395B8B52A88FAFC11CF88FBCBEBFE9F99BED79C 19AF8AD3780892 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6771.bin EMI : CNT : 001A EMI : [00] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM5V8001DM-B622 : RAM : [ 4.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6.00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100334836434142 : VEN : SAMSUNG | DEV : 3H6CAB : RAM : [ 6.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 6.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 6.00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 8.00 GB ] EMI : [0B] : eMMC : LP_DDR4X : ID : 13014E53304A394B38 : VEN : MICRON | DEV : S0J9K8 : RAM : [ 4.00 GB ] EMI : [0C] : eMMC : LP_DDR4X : ID : 13014E53304A394D39 : VEN : MICRON | DEV : S0J9M9 : RAM : [ 6.00 GB ] EMI : [0D] : eMMC : LP_DDR4X : ID : 13014E53304A394438 : VEN : MICRON | DEV : S0J9D8 : RAM : [ 4.00 GB ] EMI : [0E] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6.00 GB ] EMI : [0F] : eMMC : LP_DDR4X : ID : 450100444134313238 : VEN : SANDISK | DEV : DA4128 : RAM : [ 4.00 GB ] EMI : [10] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8.00 GB ] EMI : [11] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6.00 GB ] EMI : [12] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8.00 GB ] EMI : [13] : eUFS : LP_DDR4X : DEV : H9HQ22AECMMDAR : RAM : [ 6.00 GB ] EMI : [14] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8.00 GB ] EMI : [15] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 4.00 GB ] EMI : [16] : eUFS : LP_DDR4X : DEV : H28S8Q302CMR : RAM : [ 6.00 GB ] EMI : [17] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8.00 GB ] EMI : [18] : eUFS : LP_DDR4X : DEV : H9HQ22AFAMMDAR : RAM : [ 8.00 GB ] EMI : [19] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00039000 [ 228.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: AD014839485131364146414D4D444152 UFS: VEN : 0x01AD VID : H9HQ16AFAMMDAR IFW : A107 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 158e4dceab23000000000000 REG : 0x101010000 CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 86110B05DC77D41038316A276128B5A8 DA : USB : HIGH-SPEED Boot done! Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020 release-keys Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-12-05 Build Time : 20.11.2020 Product Info : oppo6771 STORAGE : LifeStatus : UFS : OK! Done! Elapsed: 00:00:28 Operation : Reset Settings/Format FS [ v2.20 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM131) MODE : BOOTROM PORT : 131 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : 7FEE66FC1208C993D72BF02714AB1F50 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : F11-Reno2F | Manual : Disabled BROM : SOCID : 762D23CDCF8395B8B52A88FAFC11CF88FBCBEBFE9F99BED79C 19AF8AD3780892 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6771.bin EMI : CNT : 001A EMI : [00] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM5V8001DM-B622 : RAM : [ 4.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6.00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100334836434142 : VEN : SAMSUNG | DEV : 3H6CAB : RAM : [ 6.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 6.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 6.00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 8.00 GB ] EMI : [0B] : eMMC : LP_DDR4X : ID : 13014E53304A394B38 : VEN : MICRON | DEV : S0J9K8 : RAM : [ 4.00 GB ] EMI : [0C] : eMMC : LP_DDR4X : ID : 13014E53304A394D39 : VEN : MICRON | DEV : S0J9M9 : RAM : [ 6.00 GB ] EMI : [0D] : eMMC : LP_DDR4X : ID : 13014E53304A394438 : VEN : MICRON | DEV : S0J9D8 : RAM : [ 4.00 GB ] EMI : [0E] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6.00 GB ] EMI : [0F] : eMMC : LP_DDR4X : ID : 450100444134313238 : VEN : SANDISK | DEV : DA4128 : RAM : [ 4.00 GB ] EMI : [10] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8.00 GB ] EMI : [11] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6.00 GB ] EMI : [12] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8.00 GB ] EMI : [13] : eUFS : LP_DDR4X : DEV : H9HQ22AECMMDAR : RAM : [ 6.00 GB ] EMI : [14] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8.00 GB ] EMI : [15] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 4.00 GB ] EMI : [16] : eUFS : LP_DDR4X : DEV : H28S8Q302CMR : RAM : [ 6.00 GB ] EMI : [17] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8.00 GB ] EMI : [18] : eUFS : LP_DDR4X : DEV : H9HQ22AFAMMDAR : RAM : [ 8.00 GB ] EMI : [19] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00039000 [ 228.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: AD014839485131364146414D4D444152 UFS: VEN : 0x01AD VID : H9HQ16AFAMMDAR IFW : A107 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 158e4dceab23000000000000 REG : 0x101010000 CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 86110B05DC77D41038316A276128B5A8 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:47 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to karim1980 For This Useful Post: |
