07-29-2016, 18:13 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | HTC D826w invalid imei, restored done but still invalid help Code: Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847326404050DA21A6832F3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A483847326404050DA21A6832F3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xB6EAA660BBDE98F667D45458470AC762 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 869268020714526 IMEI [01] : 869268020889674 Set IMEI [00] : 869268020714526 Set IMEI [01] : 869268020889674 Prepare finished. Security check required! Wait for phone... Phone found! [ 18 ] Sync... Repair done! Done! Elapsed: 00:00:36 Reconnect Power/Cable! Finish at : [7/29/2016 / 1:33:33 PM] nvram also giving error 0x10 at wifi |
The Following User Says Thank You to Muhammadsaqib11 For This Useful Post: |
07-30-2016, 10:43 | #3 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
Try This NV! | |
07-30-2016, 12:29 | #4 (permalink) |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | nv write successful Code: Operation : Write NVRAM [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847326404050DA21A6832F3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A483847326404050DA21A6832F3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xB6EAA660BBDE98F667D45458470AC762 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [NVCheck] : BBID : MT6582 , NVID : MT6582 [NVM] : Write Ok! [Info] : NVRAM Repair on erased/damaged phone : 1. Fix Unknown BaseBand 2. Power On phone, check BB state 3. Write NVRAM 4. Repair Security Done! Elapsed: 00:00:25 Reconnect Power/Cable! Code: Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847326404050DA21A6832F3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A483847326404050DA21A6832F3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xB6EAA660BBDE98F667D45458470AC762 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 869268020714526 IMEI [01] : 869268020889674 Set IMEI [00] : 869268020715721 Set IMEI [01] : 869268020815745 Prepare finished. Security check required! Wait for phone... Phone found! [ 18 ] Sync... Repair done! Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
07-30-2016, 13:18 | #7 (permalink) |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | i flashed with this firmware and flash done successfully after that i tried to write imei ROM ALPS D826w | [Official] add the 05/20/2015 on Needrom |
07-30-2016, 14:14 | #8 (permalink) | |
seems hw - base band ic problem check in hw | |
