Htc Desire 526G+ dual sim D526h SECURITYBOOT_BOOT_NOT_ACCEPTED problem Today I got a Htc Desire 526G+ dual sim D526h in blinking condition. This set's bootloader is also secured by company.So I can not flash it. Fastbootmode as well as Recovery mode is not coming also(by using vol+ or Vol-) keys. So I can not flash it via sd card or fastboot comands) In last 3 days I have got 2 sets in such problems. Please solve this problem.............. Log: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 56 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! |
Hello. Did you try select HTC mode? |
I do not have knowledge about htc mode.How to enter htc mode and how to operate in this mode???? Please explain......... |
Select last line in CPU settings. Will be available new menu under it. Select HTC. Do need operation. |
Still same problem Sir 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 56 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
put phone in fastboot mode .use adb and force device in to recovery mode then use sd card update . i done the same way my phone also notgoing into recovery by this method u can solve . |
Is there any other way to bring it in fastbootmode?????? Plz help............... |
