10-22-2017, 06:43 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: meerut
Member: 804463 Status: Offline Thanks Meter: 77 | cm2 bed story https://ibb.co/kgmtJ6 Start at : [10/22/2017 / 10:32:36 AM] Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41C [eMMC] : FLASH_CID : 150100524331344D420754A6D849B319 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0xCBA418B76DFB83DCB06CFD1FB8DBC395 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! USBDL : Init HSUSB Ok Reading data ... [Error] : Bad Magic! Encrypted FS! [Info] : DP Lock not set! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
10-22-2017, 13:44 | #3 (permalink) | |
Member: 804463 Status: Offline Thanks Meter: 77 | Quote:
Start at : [10/22/2017 / 11:27:14 AM] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41C [eMMC] : FLASH_CID : 150100524331344D420754A6D849B319 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0xCBA418B76DFB83DCB06CFD1FB8DBC395 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! Clear RDP Clear Error! Done! Elapsed: 00:00:16 Reconnect Power/Cable! mircle box 1 clik ok | |
