Huawei G6603 Unlocked 100% !!! Hi All, The model has been sucessfully unlocked with infinity box ... Just select huawei G6600 and proceed with the normal process ... following are the logs ... COM3 [VCP0] selected module v3.63 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G6600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2PY01V01.04 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 35353704011957 connection Ok 189 byte(s) read reading data... reading data #2... building new data... writing data... 177 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 22 sec Remove/Install battery now ! BR / Manbir |
Thanks a lot for information ! Please, read full flash from this phone and send full flash backup file (or link) to [email protected] |
Tested on a clients phone donot have it now, however will post the complete details next time around ... BR / Manbir |
i´m desperatly about the cable. how to soldering in the back of the phone. Please help me to do that!! Best Regards |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell. It's just an example for Alcatel, if you have another model you must select your model ! http://www.infinity-box.com/download...shell_v126.jpg RJ45 connector pinout: http://www.infinity-box.com/download...pins_small.jpg Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum |
Fbus pinout cable for huawei g6603/vm820 Hello everyone i have just unlocked a huawei g6603 locked to virgin uk i know this maybe old news but i put it up anyway incase someone needs the info using z3x box and nck software i was able to unlock the phone with ease now i looked at the forums and the usb cable option wasnt good but what i did was i spliced a mini usb to reveal 4 wires red green white black now what i did i got a spare rj45 plug and i inserted 3 of the wires into postitions to create a fbus cable green in postition 2 white in postition 3 black in postition 7 on the rj45 plug, you dont need the red cable. now once thats done picked the phone up with ease, this pinout is for the z3x pinout layout might not work with ufs box. hope this helps someone down the road |
Unlock Huawei G6620 need help please Quote:
Hi Have you schematic for pin on RJ45 (output) on this Huawei G6620 ? Thanks |
