Old 03-03-2011, 17:03   #1 (permalink)
buntymurarka's Avatar
Member: 503911
Thanks Meter: 195
Forme Mobile invalid sim problem
After successfully rebuild IMEI with Chinese miracle of Forme mobile 3 times the mobile shows invalid sime after some times and the IMEI number changes to 1353265.........
I had changed several IMEI in the same phone, still the IMEI changes to 1353265......... and the phone shows invalid sim. Whats the solution to this problem.
Old 03-04-2011, 03:23   #2 (permalink)
.::Gsm_Srilanka::.'s Avatar
Member: 1133072
Thanks Meter: 505
restore original imei 1 and 2
Old 03-04-2011, 03:52   #3 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Change imei with the default firmware inside method.
Post result.
Wr.
Old 03-04-2011, 06:47   #4 (permalink)
Member: 503911
Thanks Meter: 195
already stored default IMEI but giving invalid sim after some time
and how to
Change imei with the default firmware inside method.?
Old 03-04-2011, 09:01   #5 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
and how to
Hello,
Open chinese miracle- go to "Service" page-press option where written "imei #1 for dual sim/mono cpu"- there you will see last option "imei #1 (defaut imei inside firmware )".
Try with that option.
Wr.
Old 03-04-2011, 11:41   #6 (permalink)
Member: 503911
Thanks Meter: 195
yes i done but i want to know how this process work and what is the difference between normal IMEI rebuild and default IMEI inside firmware rebuild?
Old 03-04-2011, 12:02   #7 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
In simple words you can understand that in some mobiles imei automatically gets corrupted or changed after sometime, and this happens due to firmware inside the phone which is faulty, so with this method the firmware is modified a little to write imei and imei don't gets changed itself.
Hope this much helps.
Wr.
Old 03-04-2011, 12:18   #8 (permalink)
Member: 503911
Thanks Meter: 195
thanks i wll post results
Old 03-04-2011, 12:18   #9 (permalink)
Member: 503911
Thanks Meter: 195
and what about 2nd IMEI how to write into default firmware?
Old 03-04-2011, 12:22   #10 (permalink)
N93i's Avatar
Member: 760175
Thanks Meter: 41
click mode 2 then write emei press power on
Old 03-04-2011, 22:16   #11 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
did you succeed in writing Default IMEI #1?
Old 03-07-2011, 05:06   #12 (permalink)
Member: 503911
Thanks Meter: 195
no after some time it is still showing invalid sim......... written original imei and changed with other imei too generated with infinity software........but still same problem after some time....what may be the reason and how to solve it?
INFINITY SUPPORT pls help me out..................
Old 03-07-2011, 20:51   #13 (permalink)
Member: 148515
hello!
please post here IMEI changing log of "default IMEI inside firmware"
SIM restriction pending -- what does it mean? Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-17-2011 10:05
Page generated in 0.17289 seconds with 9 queries
